Need good oc board for E6600
superballz00
What are some good overclocking mobos that are reliable? My budget is $100-150. Closer to the $100 would be best. I won't use SLI so don't need a board with it.
Biostar Tforce 965PT. Best board at its price. Overclocks just as well as the S3 and DS3 but is cheaper and uses a VIA IDE chip that doesnt have as many probs as the Gigabyte board either.
Im only running mine at 366fsb but thats a heat issue, nothing else.
there are a few p5n-e-sli mb's out with the 650i chipset for around $130 . from what i've heard they'll do up to 500fsb .
the gigabyte ds-3 or s-3 are very good overclockers . the biostar is pretty good but i don't think it has a cpu multi adjustment yet which would be a concern if your running a e-4300 or a higher multi conroe. :cool:
The cheapest Asus P5B-E I can find is on newegg for $150. That's a little high for me rit now so I mite just wait a while.
newegg has the p5n-e-sli for $129.99 since it was put on a after cristmas sale . :eek: you might have to search pricegrabber to find it at that price though.
