Hey,
I'm running my Barton 2500+ @ 10.5 x 200 or 3000+. I've had it that way for a year or so, no real problems.
In an attempt to get quieter, I have been messing with my case fans, putting in the stealths from Vantec. I also put a Silent Cat over my Silent Boost HS.
I run Prime 95 and have temps around 52C with spikes that go higher.
I really don't think that is "good" cooling. The proc hasn't shut down or anything so it's not a lockup issue at this point.
What HS should I get to go with this Silent Cat fan? I am hoping for QUIET as I record music with this and the mics pic up everything. I also don't want it to overheat in the middle of a take, so it's kind of a trade-off I guess.
After the HSF suggestion, what should I do, fanwise, in order to maximize airflow while staying quiet? I have an Xdreamer2 case with an Antec True Power 430W PSU. The X-Dreamer has a window with an 80MM fan, and the case also has a blowhole 80mm fan.
Any help is greatly appreciated.
Augster
Augster
