Just because the H50 allows you to get to 4Ghz is a pretty poor reason to recommend it if everything else does the same. Now if it cools "better", then that makes sense, but it does not. You get the H50 for the coolness factor (and not refering to temps here) or compactness - that's it.
Megahalems. What else needs to be said.
