Ahriman4891
- Jun 18, 2005
A while ago I made this thread:
http://www.hardforum.com/showthread.php?t=1107179
asking for some input on my new computer build. I ended up getting the following:
E6300
Gigabyte GA-965P-DS3
PQi turbo 2GB ddr2-667 kit
eVGA GeForce 7900GTO
Seagate Barracuda 7200.10 320 GB SATA 3.0 Gb
Lite-On 16x DVD-burner w/lightscribe (newegg is out of black NECs)
Enermax FMA II Eg565P-VE 535W PSU
The first time I built the machine, it did not POST. I figured the mobo was DOA, so I asked newegg for a replacement. Replacement doesn't POST either. I tried all possible permutations of RAM sticks (I have 2), 12V cpu rails from the PSU, and even borrowed a PCI-x videocard from a friend to see whether my 7900gto was the problem. No result.
Now, the PQI Turbo RAM I got requires 2.0V to work on default settings. As I understand, this may be a probem, since most mobos provide 1.9V by default (So one needs a cheap 1.9V stick of RAM just to be able to boot the system, go to the BIOS and change the voltage setting). I did search around on the 'net before buying, and I did see people with this particular RAM and mobo combination, so I assumed the mobo would not have the problem. However, it seems that this is the most likely source of my troubles right now. I'll try to call newegg, talk them out of the restocking fee and replace the mobo for a different model. The question is,
Which mobo will work with 2.0V DDR2 out of the box? Or maybe there is some hack to make my current board work?
I am looking at Asus PB5(-E or regular), DFI infinity 975, MSI 975X platinum. The last 2 are somewhat more expensive than I would like, but if they make things work, so be it
this has been a very frustrating month.
Thanks for any input!
E6300
