Need cheapest web/storage server
syuri
Guys, looking to build Linux workstation on a budget. Going to use it as a storage server, webserver, to run some background apps, like torrent ... Ocasionaly to play with lightweight desktop. Nothing fancy. I already have some stuff: Case, PSU, Optical drive, can dig for old graphics card. Basically looking to get MB+CPU+RAM. Thinking about $100. Do not want CPU with power consumption > 65W
I see a deal for that combo
Zotac GF6100-F-E NVIDIA GeForce 6100/nForce 430 MCP AMD AM3 MicroATX Motherboard
AMD Athlon II X2 250 Regor 3.0GHz AM3 65W Dual-Core Desktop Processor
~$70 AR, just need to add memory. Can I get 4GB for $30? Only gripe, there is no IDE and expansion slot.
What do you think? anything else? I do not hesitate to get used, but do not want to drop CPU performance below mentioned above.
Thanks,
--Yuri
Linux server (SlackWare?) as a home web server, storage, maybe some background apps, like torrent ..., may be (ocasionaly) some lightweight desktop.
$100
3) Where do you live?
MD
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
"Everything" is not a valid answer. Please list out all the parts you'll need.
MB+CPU+RAM
Case, Power supply, may be graphics card if not on MB already
6) Will you be overclocking?
No.
LCD over DVI
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
GB Lan, prefer any onboard video, IDE or expension slot where I can stick discerete IDE controller.
Planing to put free Linux, probably SlackWare.
