prne10
- Oct 26, 2005
Hey guys. It's been a while since I've built my own system, and a friend asked for some recommendations for his gaming rig. For whatever reason, he's already purchased some of the parts as follows:
Graphics Card: XFX AMD HD 7770
Ram: Corsair Vengeance Blue PC3-12800 1600mHz DDR3 240-Pin SDRAM
DVD Drive: LG Internal Super Multi Drive 24X
Case: Rosewill Blackbone Black Steel / Plastic ATX Mid Tower Computer Case
He needs a CPU / Mobo combo for under $200 total so I'm thinking the following:
CPU: Intel Pentium G3258 Haswell Dual-Core 3.2GHz LGA
Motherboard: ASRock Fatal1ty H87 Performance LGA 1150 Intel H87
I think the above is a good bang for buck combo. At least a bit of research suggests that the G3258 is the best gaming CPU for under $100 right now. I think his other parts should work just fine.
EDIT:
CPU/MOBO Combo Proposed:
CPU: Intel Core i3-4130
Motherboard: Gigabyte LGA 1150 Intel B85
This proposed answer is probably better for non-OCing.
Also, I'm thinking this for a PSU (separate from $200 for CPU/MOBO):
SeaSonic M12II 620 Bronze 620W ATX12V
The above is reasonable price, gets good reviews, and is modular for easy install and clean look.
Thoughts?
EDIT:
Thoughts?
