Need Build Help - New Mini Gaming/Performance PC
Hanif
I live in Ontario, Canada I can order from newegg or ncix.
- Everything
- Taxes and shipping = $1200
Toronto, ON Canada
- CPU, GPU, PSU, RAM, CASE, MONITOR - I PREFER RAZER, INTEL, NVIDIA AND also KOREAN MONITORS
6) Will you be overclocking?
Yes
- I want at least a 27" monitor maybe one of those Korean ones
2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
- Dotn care
Yes Win8.1 64bit
What's the priority? Gaming? Video Editing? Virtual Machines?
Which retailer(s) do you prefer?
How high do you plan on overclocking the CPU? The GPU?
Where are you going to buy the monitor from?
Retailer: NCIX (local store), Canada Computers
I only plan to overclock a bit
Monitor will be purchased from eBay from one of those Korean ebayers. Might get a QNIX
Didn't answer the important question though.
What do you intend to do most with the computer. Are you primarily gaming on it? Primarily video editing? Gonna check facebook every 15 minutes on it all day long?
It's going to be my main computer
Gaming, website design, RDP/VPN access for work
Let's use the following as a baseline monitor:
$360 - QNIX QX2710 LED EvolutionⅡ27" 2560x1440 (Samsung PLS panel) monitor
If you pay any import charges, you're looking at a $400 monitor (if not more). You'll only have $800 (or less) to spend on the desktop, and you can't do "everything" well with that amount. Can you live without a 27 inch monitor or 2560x1440 resolution?
You never answered sticky question 5 or specified in sticky question 4 if you needed any storage (HDD, ODD, SSD). Well...?
Someone I know is selling this locally for $900
http://ca.pcpartpicker.com/p/9yDzkL
Should I just get this?
Sure, but you better be prepared (and willing) to upgrade your video card should you grab one of those Korean monitors (or "upgrade" to a 4K monitor). The GTX 680's 2GB of memory may limit you on some games when using a resolution greater than 1920x1080.
Keep in mind: most of the parts in that PC are older.
They're better than a new AMD-based system for gaming. The OP won't find a better deal on a new OC-friendly Haswell or Devil's Canyon-based system with similar specs.
