freeman2k6
- Jul 15, 2005
Hey all. Thanks for taking the time to check out my post. I did check out the sticky above so I've answered the questions below accordingly then I'll go ahead with some words of my own... basically what the situation is is that I need a performance upgrade for my gaming PC I put together about 2 years ago.
1) What will you be doing with this PC? All things Gaming
2) What's your budget? Are tax and shipping included? $500-$600 prefer to include T&S but not a deal breaker.
3) Where do you live? KY, US
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific. Mobo, CPU, RAM, Vid, new case.
PSU: Antec TPII-550
HD: WD Caviar SE 16 320 GB
6) Will you be overclocking? No.
7) What size monitor do you have or plan to have? 19" at the moment.
8) When do you plan on building/buying the PC? Between 2-4 months from now, however could be in 1-2.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc. Nothing special.
Right now the pertinent parts that will be needing replacing are:
Mobo: Asus A8N-SLI Premium
CPU: AMD 64 4000
RAM: Can't remember exact specs, was 2x 1GB sticks but one went out so running on 1x at the moment.
Video: BFG GeForce 7800GT
So the story is, I did a bunch of research--alot with assistance of these forums you'll see if you check post history--a few years ago and put a system together with the goal of being a solid gaming system that would last a while.
Well it's lasted fairly well but the case hasn't really been maintained as well as it should have, a stick of ram went bad, and I am becoming increasingly aware of how far behind the curve I seem to be.
So I'm looking to get a fairly good performance boost here if I can. I am getting back into the research stage now and I honestly haven't paid much attention to the hardware world for a long time now so any advice would be appreciated.
One thing I had picked up on was Intel's processors becoming superior for gaming with quad cores, etc. That's just what I had picked up on though so if that's not true I'm ok with sticking with AMD.
With the video card being included in the upgrade plans, I'm not sure how realistic my budget is, but it is a budget none-the-less.
On a side note, I did purchase the hard drive as a replacement not too long ago and I believe I made the right choice as far as performance value/storage goes. If that was an overly poor decision I"d like input on that as well as it relates to gaming systems.
Thanks alot for reading all of this if you have and thank you in advance for any input.
Freeman2k6
PSU: Antec TPII-550
CPU: AMD 64 4000
Freeman2k6
