Need advice on the Rebel XT
T-3
I just picked up the Rebel XT with the kit lens and now I need some help on the accessories.
First the camera is for my wife who works in a photo studio taking portrait shots. This is the one she said she wanted so I got it for her. I have no idea about any of this, so any help is appreciated.
I need some help with lenses and stuff.
1. which lense for inside portrait.
2. which lense for outside portrait.
3. which lense for inside action, like birthday parties and such.
4. which lense for outside action like picnics or events.
5. which lense filter will fit the kit lense that comes with the camera.
6. a good online site to buy these things, no store for at least 100 miles for this type of equipment where we live.
7. a case that will hold the camera and a couple of lense.
8. a flash unit. I was looking at the 430 unless i need one of the 5xx series to accomplish the above. tasks.
Thanks for the help.
T-3
Questions 1 - 4 - I would venture and say all these needs (inside/outside portraiture, inside/outside action) could be accomplished with the 70-200/2.8 lens. Granted, I mainly have experience from the Nikon side, but I love the 70/80 - 200/2.8 lenses for Nikon (gonna get one soon, I've played with one I could try). You have the speed needed for indoor shots thanks to F/2.8), and the aperture also limits the depth of field which is useful for portraiture (blurs background, etc), and the versatility of a zoom. I have no reason to doubt Canon's 70-200/2.8 is anything less than stellar, since there are tons of users with it. ;) It's certainly not a cheap lens though, probably will set you back $1600+ for the IS (image stabilization) version of the lens, while the non-IS version is $1000. Also, the lens is a little heavy, in the 2 lbs range.
If you want a wider angle shot, well, I'll leave that to resident Canon shooters, since I haven't shot with wide angle canons. Of course, the kit lens starts at a wideish 18mm, so your wife could always use that (though the lens is a little slow for indoor so you'll have to use flash or get better lighting).
Question 5 - the kit lens has a 58 mm thread, so 58 mm filters would work.
Question 6 - www.bhphotovideo.com is a nice place to shop. Also excellent rating on resellerratings.com. Just don't be lured in by a lot of the cheap prices you might find on the net, there are a lot of fly-by-night shops out there that'll take your money and run.
Question 7 - no comment, I still use a relatively small shoulder bag for my gear.
Question 8 - no real experience with Canon flashes. The Speedlight 430ex is well regarded though.
BillLeeLee had some good points, indoors I do perfer the 24-70mm F2.8L becuase the 70-200 can be too long, also the 430EX is nice inside but outside shots are better with the 580EX, plus once your good with the 580EX, you can add 430EX or two as slaves for more complex lighting.
Also remember the sigma lenses that are the same focal lenghs and apature ratings are neck and neck for performance and can save you some cash. Also Id avoid digital only lenses if you plan to upgrade camera bodies in the future execpt for wide lenses then you may not have to much selection.
Also another good portrait lens is the 50 or 85mm prime just because they are great for low light, and super sharp. Just as good if not sharper then my L lens, or for good zoom for indoor portrait is the 17-40L or 24-70L f/2.8. Lately though I have been looking at the 17-35mm f/2.8 Tamron, just because you get about 92% of the quality of a 17-40L for half the price ($350 vs $700).
A lot of people really like the Tamron. If you get a good copy it's supposed to be close to the Canon 24-70.
It really matters what your gonna use it for, the advantage is with the sigma and canon for optical quality by a bit on the other hand the extra 5mm of reach can help prevent having to do as much croping and use interpolation to get the image to the size you want for a print, I own the Tameron 28-75 F2.8, but I have rented the 24-70 F2.8L sever times and love it but with practice on the Rebel XT, and understanding how to use the optics you can get perfect results with each lens, the downfall to the tameron is its backwards to all other lenses for its zoom so it can take a bit to get use to it if you use alot of other lenses.
As a wise man once said there is a lot more bad photographers than bad copies of lenses
Thanks for the help so far.
Im thinking I should let her play with the camera and kit lense and see what she wants from there. I know that the equipment she uses at work is way over my head. I think for now im gonna get her the other accessories like a flash and some good cf cards, maybe a good carring case. Is there anything important that im overlooking for her to get started with. so far i have the camera, kit lense and one sandisk ultra II 1 gig cf card.
Thanks again for all the advice.
T-3
The AF 28-70mm f/2.8 is a great and sharp lens, a lot sharper than the Sigma. But on a 1.6crop DSLR like the RebelXT, 28mm might not be wide enough for a lot of shots. That 28mm turns comes out to be 44.8mm. But it is really good because of the f/2.8 for low light conditions and great bokah. I think a good walk around lens to start out with is the Canon 17-85 IS (around $575) or the Sigma 18-200 ($330). I love my sigma, it has a great reach and fairly wide enough for those wide shoots....
Not an expert here, but some good primes would be good. The nifty 50 (canon 50mm 1.8) is a nice, cheap, sharp starter lense. Maybe compliment it with the canon 85mm 1.8 (not nearly as cheap, but an excellent lense)
fast and wide for this. F2.0 min for good shots without having to go all the way to ISO1600 or resorting to flash. DOn't have any experience with the lenses, but candidates would be:
http://www.bhphotovideo.com/bnh/con...166&is=REG&addedTroughType=categoryNavigation
http://www.bhphotovideo.com/bnh/con...360&is=REG&addedTroughType=categoryNavigation
http://www.bhphotovideo.com/bnh/con...169&is=REG&addedTroughType=categoryNavigation
A good midrange zoom - everyone's favorite the 70-200 is a decent choice. For a walkaround I like the Sigma 18-200 (though I don't own one yet - next on the list for me)
already answered.
already answered - bhphotovideo.com. Less selection, but also good experiences for me have been bestpriceaudiovideo.com and buydig.com
Lots of options - this is what I have: (can't find it now, have to get back to you on that one - posting from lunch hour, and I gotta GO!
If she's a photographer, she'll want the flexibility and expandability (remote triggers) the 580EX offers her.
Hey, opinions are free, easy and worth what ya pay for 'em. :)
BB
n64man120 said:
If we're on the topic on linkage, my other favorite site along with FredMiranda is http://www.dpreview.com
Their forums are rather active as well
Stick to FM for forums. If you have to venture into dpreview's forums, do so with a large bottle of advil, and maybe a blunt object on which to bang your head. I honestly want to gouge my eyes out every time I goto dpreview forums.
I ordered a spare battery and charger for it.
I also ordered the tiffen uv lense filter for it.
Am I missing anything for her start with?
Thanks for all the help,
T-3
T-3
Metal case?! :D BTW why did you order a charger? The XT comes with a external plug your battery into it charger. Ie no charging IN the camera itself. And yeah i have to get a UV filter for mine but i just bought a sigma 24-135 F2.8-F4.5 lens so obviously the filter is a bit bigger (77mm :eek:) and won't fit my now non used KIT lens! :p
I ordered the charger and spare battery so I could get one charged up right before christmas, My daughter already wrapped her camera kit and its under the tree. I figure she will want to play with it as soon as she unwraps it, so now she has the extra battery and charger. I figure it will come in handy some time anyway.
T-3
