Okay, currently, I'm running the following hardware:
4 x SATA hard drives
2 x DVD-R drives
2 x GTX 275 in SLI
1 x 9800GT for PhysX
1 x X-Fi Fatal1ty Titanium
i7 920
12 GB RAM
Is there any reason that a 1050 watt supply would be insufficient for this? I'm unable to determine exactly what the requirements would be for all this.
Currently, I'm using an ABS SL1050 which seems to give a consistent and stable voltage when I measure with a multimeter. The unit has an 80+ silver rating and >85% efficiency rating. I highly doubt that it's the problem.
Just recently though, I've started seeing some odd crashes that say they're from the Nvidia driver (nvlddmkm.sys). This is in Win7 64 bit btw.
I just totally blew away and reinstalled all the nvidia drivers to see if that resolves it (I did recently move the cards to different slots for better airflow, etc. so that MAY have scrambled the drivers.).
Anyway, anyone have recommendations for an appropriate wattage for this config? Just want to make sure I'm pumping enough juice
Thanks.
2 x DVD-R drives
2 x GTX 275 in SLI
i7 920
12 GB RAM
Thanks.
