What I am currently looking at is:
Silverstone SG06
ASUS M4A88T-I Deluxe mobo (I need WiFi, and this is one of the few boards that deliver that)
Phenom II X2 555 (or Athlon II X2 245e)
2 or 4 GB RAM
500 GB 2.5" HDD, I might upgrade that later.
I plan to put GTX460 or something from ATI 6xxx series in there around Christmas time. Until then the build will be a media PC build so I am hoping it will be quiet as well
My big worry is the 300W power supply! Will it be enough for that kind of setup?
Is it dangerous running the PSU at near 100% load for extended periods of time?
I looked at some Phenom 555 reviews and power draw ranges from below 200W to over 300W, same goes for GTX 460 reviews (250W to over 300W). In both cases the CPU or the GPU is different and they take the measurements at the wall so considering around 85% PSU efficiency everything below 330-350W should be fine.
If going with 555 is a close call would it be safe to go with 245e? Seems to shave 20 or so W.
Silverstone SG06
2 or 4 GB RAM
