need advice on a new system, please <3
Ok so currently this is what im looking to buy
EVGA NVIDIA nForce 790i Ultra SLI ATX Intel Motherboard $335.99
2 GeForce 9800 GTX+ 512MB 256-bit GDDR3 $189.99 + $189.99
Intel Core 2 Duo E8500 Wolfdale 3.16GHz $188.99
Thermaltake W0131RU 850W ATX12V / EPS12V SLI NVIDIA SLI Certified NVIDIA QUAD-SLI APPROVED $229.99
OCZ NVIDIA SLI-Ready 2GB 240-Pin DDR3 2000 $154.99
Ok so this is what im looking at, and im on a tight budget and perhaps need to lower the price which comes out to 1,279 dollars. One thing I will not change my mind on are the 2 9800's
Also if this is a decent setup, will the powersupply listed support dual pcix 2.0 cards? I haven't been following the scene much anymore and im not sure what would be the best and cheapest run for the money that will handle everything when it comes to running 2 pcix 2.0 cards.
Any help on this, and possibly lowering the outcome(cost) of my current endeavour would greatly be appriciated ;3 I also hear that motherboards are picky when it comes to many types of ram, so if my current setup is the cheapest bang for the buck anyone have a clue if the ram and mobo listed above are supported with eachother?
Thanks again D:
OK, which monitor/resolution are you using? Which games are you playing? Have you bought the two 9800GTX+ cards yet? (Have you bought anything yet?)
The reason why I'm asking is this: Whatever you're planning, you can do it another way... and, possibly, for less. You would be better served with one of the current high-end video cards, which (could) allow you to obtain a cheaper motherboard, memory, and power supply.
But before I help you further, please help (us, as I'm not the only one reading this) out by answering my questions.
You're getting SLI video cards and two gigs of ram? Heh?
Can you answer tiraides questions please.. Those are some over the top expensive parts for what it seems like you won't be needing.
Well just throwing some options for you to consider. Also the 4850's are the best bang for the buck for video cards right now. So really the 9800's are really a waste of money. Also these two boards are all solid and reliable, while that evga board well lets just say i have seen several post here about it flaking out. Also .16 isn't really going to give you much of a performance gain so the e8400 is a better option. ddr3 with any chipset besides the x58's is really a waste of money for the performance your going to gain.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131284= =289dlls -x48 chipset
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131297 189dlls -p45chipset
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102770 =159dlls each
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037 =169dlls
http://www.newegg.com/Product/Product.aspx?Item=N82E168201451977 =117dlls
with the same psu if you go with a crossfire option the total comes out to 1122.99 if you go with the striker board. The deluxe board is as reliable and has pretty much the same options just on a p45 chipset , thats not considering the mir most of these items have. You get the same performance for less.
Well that's just my 2 cents.
Oh my gawd, remove every item from your list. Redo. Good lord that's poor price/performance ratio.
QFT.
Please answer Tiraides' questions. That build list really looks horrible. You could probably get a Core i7 build for not much more.
I haven't bought anything yet, nor the cards and i currently use a (dell)19inch lcd 1440x900. I will most likely switch to a 22inch lcd monitor shortly after i upgrade however. ( so please take the 1680x1050 instead of teh 1440x900 lcd as my current resolution) Which would be a dell lcd also, at then im guessing a resolution of 1680x1050?
As for games, crysis, farcry, fallout3, left for dead, and anything else in that category. The only reason i've been looking at Nvidia cards also is from the horrible past i've had with ATi especially with the 9800 series. If I can, ATi is something i'd love to avoid unless necessary. All in all i'd like a great gaming rig at a decent price and would love to experience dual SLI technology. If im going to get a SLI'd card, i'd like to have a second card go with it :p
and another question, why exactly are the GeForce 9800 GTX+ 512MB 256-bit GDDR3 cards horrible performance? They have great reviews and the sorts ;x
edit:
My current system is
Gigabyte S-series 965P-S3
Intel Core 2 Duo E6300 1.86ghz
1.5GB of mixed types of DDR2 ram - lol yah i know :O -
500watt Allied PSU
PNY GeForce 9800GT 1GB DDR3
( a friend is letting me borrow till i rebuild a new pc My 7600GS finally bit the dust)
Sad to say, even though hes letting me borrow this card until i rebuild my pc I have noticed it performs worse than my Nvidia 7600GS 512mb DDR2 card did. I take it, its the fact my motherboard doesnt support pcix 2.0? ( although everyone says this isnt an issue.) The fact im using mixed sticks of DDR2 ram doesnt help either :p
I've never had a problem with this mobo or build, but it only has one SLI x16 slot which isnt pcix2.0. Bleh, I just need a whole new system :p
My system is apparently horribly bogging down the results of this 9800GT hes currently letting me use.
edit2: 3dmark06 results shortly for the lulz.
5742 3DMarks
You don't need SLI (or CrossFire) for either resolution (and yes, the resolution of a 22 inch widescreen LCD monitor is 1680x1050). And AMD/ATI has hit a home run with its HD48xx series cards -- they're just as good as their NVIDIA equivalents (the new GTX 2-series, which are the current high-end cards for NVIDIA).
Here's a different way to go with this:
$250 - Asus P5Q Pro & Intel C2D E8400 combo deal (free shipping on both)
$41 - Xigmatek HDT-S1283 & ACK-I7751 retention bracket (free shipping on both & $10 mail-in rebate on CPU cooler)
$55 - G.Skill 2x2GB DDR2 1000 kit (free shipping)
$290 - Sapphire HD4870 (1GB) or EVGA GTX 260 (216SP) (free shipping & mail-in rebate for either card)
$120 - Corsair TX750 750W PSU (free shippping & $20 mail-in rebate)
$756 - Subtotal (not including shipping, taxes, or rebates)
This setup performs just as well for your needs as your initial build, all for a fraction of the cost.
- The E8400 performs just as well as the E8500 and has the same OC thresholds as well. The bundle deal with the Asus P5Q Pro motherboard -- which has dual x8 CrossFire (which, again, you don't need) and PCI-E 2.0 support -- makes it even cheaper.
- The aftermarket CPU cooler (with retention bracket) and DDR2 1000 RAM enables you to overclock right off the bat, if you want to.
- Either video card would be enough for your resolution. (I chose them under the assumption that you would be getting the 22 inch monitor soon.) The EVGA GTX 260 is the better choice out of the two, since it has a limited lifetime warranty and a free copy of FarCry 2.
- The Corsair TX750 was chosen under the assumption that you ignore my suggestions and go with a(n) CrossFire/SLI setup anyways. It's just as powerful as the Thermaltake 850W PSU (in its 12V rails, where today's components get most of their power from) at less than half the price.
As for why you don't need CrossFire or SLI:
Markyip1 said:
Just some info on SLI / Crossfire: It's absolutely not worth considering if a) you're gaming at a resolution under 1920x1200 (as you'll see no performance benefit over a single card,) and b) if you plan to buy one card now and another later. SLI / Crossfire as an upgrade path is usually a very poor idea, as by the time you're ready to get that second card, a new single card solution will likely be available that will outperform two of your older cards in tandem. Furthermore, there really is no cost benefit to the SLI Upgrade Route, as any additional cost in getting the new card can be easily mitigated in most situations by selling the original. By avoiding an SLI / Crossfire solution when it will not be of benefit, you gain a cooler running, simpler to maintain system and more importantly, access to a much better (and broader) selection of motherboards.
Are you getting anything else with this build?
Yes, it will be all im getting with what you just listed and such, and that is a rather great setup.
So with a 22inch lcd I wouldnt know the difference with SLI correct? Which means I would have just as equal performance with one of those single cards you listed when playing games such as farcry fallout or crysis? What settings would such games be able to manage to keep a decent and smooth fps in any of those games? I would assume maxing out the settings wouldnt be a great idea to do or are you confident enough being able to max out the games video/ and card settings it would still perform with no noticable fps lag and such?
Crysis is a horrible barometer to design your system around, as it's created primarily to tax video cards with its high visual settings. Other than that, a(n) CrossFire/SLI system is overkill for most games played at a resolution of less than 1920x1200 (especially if you're getting two of the above cards). You won't notice enough of an improvement (outside of Crysis, which I wouldn't recommend using High/Ultra settings on) to justify the additional cost.
Ok awesome, thanks for the information. It's actually helped out a lot. I never knew that SLI was pretty much worthless at a lower resolution than what you have told me. So even games that tax video cards with its high settings at a 22inch lcd resolution it still wouldnt make a difference then.
One other question, having DDR2 system memory wont affect the DDR3 memory a video card has as well? Like it wont offset eachother or bog eachother down in any way?
No, they're two separate things. The only time the video card memory would affect the system memory would be while you're using a 32-bit OS. The long story short is that, due to the 4GB limitation that 32-bit operating systems have, you lose some "usable" RAM so the system could recognize the video card memory (as well as memory that other components may use). Using a 64-bit OS avoids that limitation.
As for the games, most of them easily max out at certain resolutions to the point that you'll see no noticeable difference between a lower-end card (say, a 9600GT at a 1280x800 resolution) and a higher-end card (like, a 9800GTX+ at the same resolution). In your case, it's not that there wouldn't be any improvement with a dual HD4870 CF setup (since you can't use SLI with the board that I chose for you, and NVIDIA's SLI boards are less stable, in general, than CF-supporting Intel boards) but that you would be paying hundreds of dollars more for meager (noticeable) improvement.
Most 22" Widescreen LCD monitors do have a max res of 1680x1050
They have good performance but horrible price wise considering that the HD4850 performs on par if not better than the 9800GTX but is siginificantly cheaper.
500watt Allied PSU
I would not be surprised if that Allied PSU was the cause of your 7600GS's death. Allied is well known for making shitty PSUs capable of killing PC hardware. However it would not affect your performance. But I'd get a new PSU nonetheless like this quality PSU:
Antec Earthwatts 500W PSU - $50
Whether or not your motherboard has PCI-E 2.0 is a total non-issue. There is another factor at hand that's lowering the performance of your system. Have you done a reformat? Reinstalled and updated the drivers? Have you tried overclocking the E6300? You should be able to hit 2.5 to 2.8Ghz with no problem, even on the stock HSF.
We have similar systems (GA-965P-DS3 and the 9800GT is a slightly more energy efficient version of my 8800GT) and I did not see lower performance when I moved from a 7900GS to my 8800GT.
Yah I did actually reformat after i popped in the 9800GT my friend is letting me borrow and said, "wtf?"
Did you see my 3dmark06 score posted above? :p I did reinstall all drivers, updates and the works, the only thing i have not done is messed with bios drivers and the such, which may be the case in the matter? I dunno.
5742 3DMarks
Sorry for this slight bump, but i had another curious question what makes more of a difference in a videocard the clocks speeds or the stream processors?
Im leaning towards the GTX 260 obviously, it has outstanding reviews but noticed the core clock is 576MHz with 216 stream processors while the card my friend is lending me till i build my system is only half the price has higher clock speeds 9800GT 1GB DDR3 but less streaming processors which is 112
So my question is, are core clock and memory clock speeds less important than stream processors?
Yup. Considering the fact that when you enable AA and AF. Now, although some video cards may have a lower core clock and memory clock, they would increase the core clock and memory clock to compensate for its lower stream processors. An example:
Geforce 9600GT with 64 stream processors
Geforce 8800GT with 112 stream processors
The 9600GT in some cases will come pretty close to the performance of a 8800GT. But, what they do is increase or factory O/C the core clock and memory clock. In the end though, the 8800GT with 112 stream processors overall outperforms the 9600GT. You can O/C a stock 8800GT with 112 stream processors. But, you can't add more stream processors to a 9600GT.
In addition you have to factor in the GPU that the video card is based on. The GTX260 is based on the G200 GPU IIRC whereas the 9800GT is based on the G92 GPU.
Anyway, I don't keep much stock in 3DMark06 so those numbers you posted means absolute jack to me. Are you sure that you have the 9800GT? Are you sure you're using the latest video card drivers? Are you sure that you're using the latest motherboard drivers? Are you using a stripped down version of XP?
The more stream processors the better, but to get a good idea when comparing the cards, you have to read reviews. Use gpureview.com to compare the cards.
What speed is your CPU overclocked to?
Hold on, I will whip up 3 sick builds to choose from with a 22" display at around $900 total and under. Hehe.
Oh it wasn't a complaint of how horribly this 9800GT 1GB GDDR is fairing on this system it was just a curious of questions since i do not believe im going to go dual/SLi and just use a single video card.
However to answer your questions my 2duo is at stock speeds of 1.8ghz. All my drivers are up to date but bios, and the likes, also xp is updated with SP2
As a good example, i figured a card like this would be able to run atleast 50-60FPS on WoW but i've noticed maxing out my settings in WoW leaves this rig at a whopping 30-35 FPS. Heck, I was even trying to play a HL1 mod earlier called NaturalSelection and I couldnt even hit 60FPS it was around 40-50 also running at a resolution of 1440x900( for WoW) i dont recall what resolution i had set for natural selection.
I was just curious as to what was faired better, the higher clock speeds or more stream processors, but from what a previous poster said, it does appear that even though a card may have higher clock speeds it seems that it doesnt matter at all unless it has the stream processors to back it up.
Build 1: Quad Core Q6600 System
CPU - Intel Core2 Quad Q6600 for $190
Mobo/Ram (Combo Deal) Asus P5Q Pro + OCZ Fatalty Edition 4GB(2x2GB) DDR2 800 for $133($15 MIR on Asus Mobo)
Video - MSI Geforce GTX 260 for $215($40 MIR)
PSU - Antec EA650 for $70 w/free shipping
Heatsink - Xigmatek HDT-S1283 120mm rifle for $32($10MIR) w/free shipping
Retention Bracket - Xigmatek ACK-I7751 for $8.50 w/free shipping
Monitor - LG L227WTG-PF 22" for $260 at Best Buy
Total: $640.50 + monitor = $908.50
Build 2: Dual Core E8400 System
CPU - Intel Core2 E8400(3.0ghz) + Asus P5QPro mobo combo for $250($15 MIR on mobo)
RAM - 4gig G. Skills DDR2 1000 for $55 w/free shipping
Total: $630.50 + monitor = $890.50
Build 3: Dual Core E7300 System
CPU - Intel Core2 E7300(2.66ghz) for $120
Total: $578.50 + monitor = $838.50
By the way, you can do this also. Pop your Intel Core 2 Duo E6300 (1.86ghz) CPu and put it in either Build 1 or Build 3. Then o/c your E6300 on the P5Q Pro Mobo with with the Xigmatek heatsink and 4 gig OCZ DDR2 800 RAM. You can save more money here.
Bump that CPU to 2.8Ghz at least and then see how your system performs. I think your CPU clock speed is holding your GPU back.
thanks hardware this is just a card that my friend is letting me borrow till i build my own system. Which someone posted on the first page a setup that seems right for me. I wont be keeping this card at all when i build a new system. I was just asking what was better on a GPU faster core speeds or more streaming processes :p and enginurd answered that for me :x Thanks though!
" Here's a different way to go with this:
enginurd ill go ahead and give it a try and see what happens and report back. Might not be tonight though, but ill give it a shot tonight.
edit: updated bios, OC'd to 2.0ghz and seen about a 100 point increase on 3dmark06 so i guess the processor is whats holding the card back. I cant OC higher though with this crappy stock cooling :p
Ok well the setup that was suggested to me was this right here
Well my other question now is, with a setup/system like this would it be worth getting a ATI Radeon HD 4870 X2 if i had the money to dish out? Or considering the fact its basically like a crossfire card and my resolution isnt very high it wouldnt be worth getting? Also would getting a card like the 4870 X2 not work its magic with such a setup as above? and would a 750watt PSU handle a 4870 x2?
and another question :p will a 24pin PSU work on a 20+4pin mobo? Dumb question i know, but blargh :/
As of right now i can possibly get by with building a 1,000 dollar system, but not much higher than that. With adding a second set of 2GB's of ram and the 4870 X2 it would bring my total to 984.00 w/o shipping costs
What are your load temps at 2Ghz with the stock cooling?
1) Well my other question now is, with a setup/system like this would it be worth getting a ATI Radeon HD 4870 X2 if i had the money to dish out?
2) Or considering the fact its basically like a crossfire card and my resolution isnt very high it wouldnt be worth getting?
3) Also would getting a card like the 4870 X2 not work its magic with such a setup as above?
4) and would a 750watt PSU handle a 4870 x2?
5) and another question :p will a 24pin PSU work on a 20+4pin mobo? ...
1) depends on your resolution. If you have a 24" or larger and game at 1920x1200 on high, then yes, it would be worth it, IMO.
2) If you're resolution is lower than 2MP (1920x1080), then no, the HD4870X2 is not worth getting.
3) Huh? That E8400 setup is more than enough for such a card.
4) More than enough.
5) 20+4 is rarely a term for a mobo. Its typically a term for a PSU. Did you mean..
a) old mobo with 20 pin main atx connector + 4 pin P4-12V cpu connector? If so, depends.
b) mobo with a 24 pin main atx connector? of course.
I was just curious because the PSU said 20+4 while the mobo just said 24.
I couldnt tell you what the load temps are i have nothing installed to view them, but I could check. I just know my system shut down from overheating at 2.2ghz and when i stuck my finger on the block I coulda fried an egg :p
The fan also sucks, with a total 3k rpm. I've tried to increase the fan speeds with speedfan once before but to no avail.
I guess i could go with the HD4870x2 if its worth it. I know the price is kind of steep, but i could find a way to pull the cash out of my pocket for a 24inch or bigger LCD. Although i really cannot complain about the 19inch i currently have. Perhaps i could pawn it off for about 80 bucks or so to throw towards a larger LCD. basically I do plan on getting a larger lcd eventually, and would prefer a setup i wouldnt have to upgrade for awhile and it seems the HD4870x2 would be the way to go without having to upgrade for along while afterwords.
Get CoreTemp or RealTemp and report back your core temps.
If you don't have a 24" monitor, then you don't need the HD4870X2. Its around $500? You're better off buying two $250 cards. One now to suffice your needs, then another one later, when it can no longer play the games you like at the settings you want. If you do have a 24" monitor, the HD4870X2 will last as long as a standard card would for a lower res monitor. :p Okay, maybe slightly longer, but not much.
err, oh wow, you dont even want to know what my temps are registering lol.
82C idle
the block is seated properly, has enough artic thermal, the block itself is clean, and as i mentioned earlier my fan is only running at 1.9k rpm atm. Which is rather sad, and like i mentioned earlier i even tried speedfan to alter my cpu fan speeds but to no avail. My case is also currently open btw, with decent airflow through the room, with a room temp of about 68F I like it cold in my house lol.
I've always figured there was something wrong with my fan since the day i installed it >.>
edit: eggs anyone?
OMG :eek:
I don't know much about temps on C2D, but 82C at idle??
Isn't that like a toaster oven?
c2d temps idle OC'd i've seen sitting idle at 55C >.> This block and stock fan just has to suck horribly lol
IIRC, the max for the chip is 90°C before it starts the throttle itself (and eventually shutdown). Are you sure those are load temps? 82°C for both cores? which program were you using and what was the Tj max value?
I'm answering the PM here, since it's relevant to the topic on hand:
pieceofcaek said:
Instead of one of the two videocards you suggested what about the ATI Radeon HD 4870 X2?
updating the 2GB's of DDR2 ram to 4GB of the link you supplied me that would bring my total to $984.94
Do you think my system would fair well for this? or would its slower DDR2 tastes, and 3.0ghz duo processor would slow this card down to where its not worth buying? If it is, do you think you could recommend me a system to fit around this card that is less than 1,1000 dollars if possible?
When (exactly) are you getting the new monitor? (Don't say, "After this build...." Give me a time estimate, in months, years, or whatever.) Which monitor do you have in mind?
You have no reason to buy an HD4870X2 for anything less than a 1920x1200 resolution (or, at least a 24 inch widescreen monitor), and only if you plan on getting the monitor within the next six months.
There's a reason why I gave you those parts recommendations: They work. So well, in fact, that HardwareGuru repeated them in his post. (Why do you think I would waste my time giving you bad information?)
... Speaking of which, which case, CPU cooler, and fan(s) are you using? (Where do you have the fans positioned?) The temps on your processor shouldn't be that high. Which troubleshooting steps did you take prior to making this thread? And how long were you having these heat problems?
It wouldnt be longer than 2 months after the build would i be able to grab a monitor. Leaning towards the dell 24inch
I also reapplied new thermal paste to my current system and i now get idle tempatures around 40-42C and around 51-56 under load, also overclocked to 2.0ghz I haven't tried to push it further although it seems i could possibly hit 2.4 or 2.5ghz with no problem at all now and i've seen a great deal on improvements with my FPS now.
Please answer the rest of Tiraides' questions.
IMO, you do not need to spend the extra $300 for a new system. Just get a better HSF, PSU and video card, overclock the E6400 to ~3.0Ghz and you'll be set. You don't need to buy DDR2 1000 RAM, Asus P5Q Pro mobo or the E8400 to improve your gaming experience. Just a few purchases for around $300 to $400 is all that you need to update your gaming performance.
Whatever you decide do, decide it quickly. I'm betting that the Allied PSU you're using right now is killing your system as we speak.
Turn off the Smart Fan option under hardware monitor... it'll make the fan run faster so you'll idle cooler... not like you need to, but some people like idling in low temps. :p I agree, you don't really need to replace your mobo/cpu/ram, but its up to you. I try to space out my upgrades so that I feel more of a difference between them.
well for answering the rest of his questions, i have an open case, with just stock fan and heatsink. As for what enginurd mentioned i have turned this off, well not exactly turned off but i made the normal operating fan speed at 60% instead of the default 25% and pushed my processors to 2.4ghz running 41C idle and around the same, mid/upper 50's under load.
As for case fans i have one in the back blowing air out, while i have a minature fan clipped to the top of the case blowing in air, from a nearby hole in my floor where a heating duct used to be but isnt there anymore :p
Can you give us any specifics? Like, which specific case are you using? Which specific fans do you have?
If you don't know anything, could you at least give us a picture or something, just so we could (try to) help you out?
