K fellas, my current rig is basically an ancient AMD Barton setup with 1gig of ram 40gig HD a Radeon AGP GTO 8XX series video card etc... as you've already established I'm on a fossil of a machine. I've got about a week to price and order a machine. I want to stay between 1000 - 1500 dollars, it would be ideal to stay under 1500 don't want to push it and catch major wife aggro!
Anyway im reusing my case and monitor... I've got a good case with 2 extractors and 2 intakes on it plenty of room to work in it and in over all good quality. I'm also reusing my monitor which is the following: http://www.newegg.com/Product/Product.aspx?Item=N82E16824001234
I've got a nice monitor but now I need a PC that's worth a damn to go along with it. I'll also be reusing my keyboard, mouse, and DVD Drive/ 3.5 drive off my current setup
K, so here's what I use my PC for on a daily basis.
I play World of Warcraft, Typical Internet usage, etc... I basically want a gaming machine, but not a high dollar one that will put me over my budget. Massive Storage space is not an issue for me. I don't plan on over clocking.
I'll need a:
1. Motherboard
2. CPU (I was an AMD guy, but i can do the Intel thing)
3. Memory (Preferably 4 gigs)
4. Good Cooling Fan/ heat sink! (It's important)
5. O/S I understand from reading the forums there is a Vista 64 for PC builders out that's rather cheap compared to the retail versions.
6. Video Card (This is important to me, but as stated before I don't want to go way over budget)
7. Good Descent sized Hard Drive (notice a lot of people recommending the 500gb Barracudas)
8. PSU
Note: I do have a Sound Blaster Audigy but from what I've been reading there is no Vista 65 Support for these cards. Is this correct? will on board sound be just as good or can I reuse my card?
I hope you fellas can help, I don't have much time. The opportunity to purchase a new rig just arised and I have to make some quick moves before that money is gone.
I'll need a:
1. Motherboard
8. PSU
