Non-gaming, work related stuff, web browsing, uploading photos, multitasking.
Under $800 after tax and S&H.
3) Where do you live?
California
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
CPU, MB, RAM, GPU, Case, PSU, DVD-ROM, DVD-RW, HDD, LCD monitor, KB&M, PC speakers.
None. Only thing from old computer that will be used is the HP printer/scanner/fax machine.
6) Will you be overclocking?
No
22" with 1920x1080 resolution.
Would like to start buying the parts within the next 2-3 days.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No more than one PCI-E x16, onboard sound, good amount of USB ports.
10) Do you already have a legit and reusable/transferable OS key/license?
No
Parts I'm looking to get
Monitor - Asus VH226H 22" Widescreen LCD [$170]
MB - Asus P5QL Pro LGA 775 [$86]
CPU - Intel Core 2 Quad Q8300 2.5GHz LGA 775 [$166]
RAM - OCZ Reaper HPC 4GB (2x2GB) DDR2 1066 [$53]
GPU - Gigabyte Radeon HD 4350 512MB [$40]
HDD - Western Digital 640GB [$70]
KB&M - Logitech Deluxe 250 [$18]
PC Speakers - Sony 2.0 Active Multimedia [$22]
OS - Windows Vista Home Premium 32-bit [$97]
Case - need suggestion. mid tower with good airflow.
PSU - need suggestion. good quality and stable.
DVD-ROM - need suggestion.
DVD-RW - need suggestion.
Total so far: $722 before tax and S&H.
This build is for my sister. She finally decides to replace her 5+ year old computer. I'm constantly searching for the best prices from online retailers, B&M, and trade forums (HardForum and Anandtech). Any suggestions or alternatives would be greatly appreciated.
Thanks!
California
No
No
Thanks!
