Need advice from the pro on build
wackojedi
I am trying to assemble parts for a new build and have been doing a lot of research on many websites/forums. Based on so many posts, its clear that I need professional advice (thats why I'm here):D . Please note that the following list of components have been acquired already and I am looking forward to using with the new build.
  • Case = Antec Solo
  • PSU = Corsair CMPSU-520HX
  • Graphic Card = EVGA GeForce 7900GS 256MB GDDR3 PCI Express x16 KO Video Card
  • Memory = Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model BL2KIT12864AA804
I am looking for a motherboard but I'm pulling my hair out trying to get something that sits well with the majority of the people. I am trying to stay under $150 for the motherboard in this case as well. The following is a list of motherboards I researched which tend to fit the budget but cause grief in making a final decision:
  1. Gigabyte GA-965P-DS3 - Apparently there is no clear consensus of my memory being compatible with this motherboard
  2. ASUS P5N-E - The memory sits well with this board based on posts by owners of the board and memory
  3. Gigabyte GA-N650i**-DS4 - This board is so new, not too many reviews about it, but the vr-zone review gives is great praise
If you all can review my post and provide feedback, I would appreciate it. Final note is that I surely would like to overclock to be in league with all of you :D and I plan to purchase a Intel E6420 C2D CPU but wanted to get clarification on the motherboard first,
Thanks all for your help.
Well the DS3 is a fan favorite for overclocking. Don't think you'll have any problem with using that RAM with the DS3. I have the DS3 myself and I was able to reach 3.2Ghz with the E6400 with some cheap G.Skill RAM. So you should be able to get a similar overclock to mine if you go with the DS3.
I looked at your build and its very similar to what I am looking to build. Currently I have 2 250GB IDE Drives which ill use with the machine until I replace them with SATA drives. I wont plan on using a DVD burner in the machine since I have another machine for that in the interim. Considering the DS3 only has 1 IDE port, putting the optical and IDE on the same chain is not recommended. Thanks for the reply so far :D
