Breath_of_the_Dying
- Jan 8, 2007
My friend wants to build a rig before borderlands 2 comes out. Beyond normal surfing and video watching online, it will mainly be used for gaming. I'll be building it for him, so to play on the safe side I'm not going to be overclocking anything. The last upgrade i made for my computer was dropping in a 6950 and unlocking it to a 6970, and you can see that my computer was built a pretty long time ago, so I'm out of the loop on good prices for current tech. Thanks for all the help!
Mainly gaming, nothing processor intensive beyond heavy gaming
I'll have to get back with that, I'm mostly looking to get help on bang/buck on the build I put together
Dallas, TX
See list below on the parts I recommended to him
He's selling his old computer, so it will be a brand new rig to my knowledge
6) Will you be overclocking?
None
His current is 1280x1024, but will most likely be selling it with his old computer. I'm going to recommend a 1920x1080 or 1920x1200 res monitor
Before end of August
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Nothing special, just fast and smooth for gaming
Will be buying an OEM Win7 64bit home from Newegg
CPU:
($209)i5-3550 Ivy Bridge: http://www.newegg.com/Product/Product.aspx?Item=N82E16819116505
or
($199)i5-3470 Ivy Bridge: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115234&Tpk=3470
GPU:
($279 after $30 MIR) XFX Core Edition FX7870 2GB: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150604&Tpk=N82E16814150604
Motherboard:
($279) ASUS P8Z77: http://www.newegg.com/Product/Product.aspx?Item=N82E16813131820
Given the rest of the system, this might be overkill for everything else since he doesnt need all the bells and whistles
PSU:
($109 and comes with a $10 prepaid card offer) Corsair TX750V2 750W Bronze: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
Memory:
($42) Corsair XMS3 2x4GB DDR 1600: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233202
Case:
($144) Cooler Master HAF932 Advanced: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
OS:
($99) Win 7 OEM Home Premium: http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Hard Drives: I sent Him a recommendation of 1 platter, and up to 2 SSDs (one for OS other for gaming and other apps). He'll probably go with the 1HD + 1 SSD option
1 HD: ($89) Samsung F3 1TB: http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
1st SSD: ($109) Crucial M4 128GB: http://www.newegg.com/Product/Product.aspx?Item=N82E16820148442&Tpk=N82E16820148442
2nd SDD (if he wants a second one for OS only) ($59) OCZ Solid 3 60GB: http://www.newegg.com/Product/Product.aspx?Item=N82E16820227728
Then I told him he'll still need all this for a fully functional computer
Monitor
Mouse
Keyboards
Speakers
DVD drive
Dallas, TX
None
CPU:
or
GPU:
Motherboard:
PSU:
Memory:
Case:
OS:
Monitor
Mouse
Keyboards
Speakers
DVD drive
