Need a new mobo (AM2 socket)
RTW
I need to get a new motherboard.
It needs to be AMD Anthlon AM2 capable, compatible with ATI Radeon cards (crossfire is not necessarily a priority.)
I have found two that seem pretty good.
MSI K9A Platinum
http://www.msicomputer.com/product/p_spec.asp?model=K9A_Platinum&class=mb
ASUS M2R32-MVP
http://www.asus.com/products4.aspx?l1=3&l2=101&l3=328&model=1296&modelmenu=1
I'm looking for a pricerange of about no more than 160$.
If anyone can comment on these, or add any others that might be better for what he needs, that would be great.
If you're not going to use crossfire, you can get any AM2 board. I've always preferred Nvidia chipsets to the ATI ones. If you're going to go ATI, get the newer 690 chipset rather than the 580X. You won't have a problem running a single ATI card in either an Nvidia or ATI chipset board.
