Need A New m-ATX Gaming PC
aznpotpie
Since I am unsatisfied with portable gaming on laptops I want to build a small gaming rig. I need a case that fits a m-atx board, HD 6970/GTX 580 while having good air airflow and still keeping a small foot print.
My hardware:
i7 2600K
Asus m-ATX Board
8GB DDR3 Ripjaw X
Seasonic X series PSU (not sure how many watts)
Not sure about the GPU but something high end
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112315&cm_re=A04-_-11-112-315-_-Product
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163177
Was looking at those two, any idea if they'll work?
Small foot print? That means less space on desk, right? In that case you would want a mini tower like the Cooler Master Elite 341. NZXT and In Win also makes mATX cases that can fit high end stuff.
I'm a bit mixed on their conclusion. I like how the FT03 is shaped but I like how the A04 has two front fans, one top and probably one in the back.
I have actually had the Cooler Master Elite 341, was hopping for something a bit smaller then that.
pc-v354 or the ft03
Which one would you like more?
Those are the 2 cases I was considering when I was looking for a matx case. I went with the FT03 in the end because it looked like it had better cooling, a smaller footprint and didn't have the psu in the way that would require the removal of every time you wanted to get to something on the board. Plus the v354 was out of stock. Both cases would serve their purpose pretty well though and I think it really boils down to your personal preference with respect to their aesthetics.
You might want to re-evaluate all the cases mentioned in this thread so far: Check the dimensions:
Coolermaster Elite 341:
Dimensions(L x W x H): 15.75" x 7.28" x 14.37"
Silverstone FT03:
Dimensions(L x W x H): 11.18" x 9.25" x 19.17"
Lian-Li A04A:
Dimensions(L x W x H): 18.11" x 7.4" x 15.19"
Lian-Li V354A:
Dimensions(L x W x H): 16.56" x 13.82" x 12.07"
As shown above, none of the three lower cases are actually any smaller than the Elite 341.
EDIT: If you want a case that's actually smaller than the Elite 341, take a look at the $190 LanGear Da Box:
http://www.lan-gear.com/langear-microATX
For comparison:
Lan Gear Da Box:
Dimensions(L x W x H): 14.6" x 11.4" x 8.6"
Besides that, you may have to wait for a mITX P67 motherboard to come out if you want any smaller.
I'm a bit concern about the cooling of the FT03. With an overclocked i7 2600k and GTX580 would it be suffice? Also what heatsink were you able to put under there?
Silverstone FT03:
Lian-Li A04A:
Lian-Li V354A:
For comparison:
Lan Gear Da Box:
Hmmm your right, well I take that back then. I want something that looks nicer? Don't know now haha but I defintely want something on my desk that isn't a standard looking case.
I have my 2600k at 4.5GHz@1.375V in the FT03 using a Corsair H50 on the oem TIM and the temps are mid to high 30s idle and and around mid 70s on load. Not the best for sure but then again it's the middle of summer here and I have one of the bottom case fans disconnected because I find it a bit loud. Getting replacement fans soon.
If I'm looking at this correctly, the bottom only has an area for one 120mm fan right? Also am I the only one paranoid that there is no fan blowing on the hard drive???
There is one 120mm intake fan angled towards the 6950 (this is removable and can be replaced with 2x 80mm fans) and a 120mm intake fan angled towards the CPU, sitting above the PSU.
Silverstone FT03:
Lian-Li A04A:
Lian-Li V354A:
Actually the FT03 has the smallest foot print out of all the cases listed there (length x width). Height does not effect the foot print. If the case is on a desk or floor, the physical volume of the case doesn't matter unless you are carrying it around to LANs or such.
With FT03, in addition to the footprint of the case itself being the smallest, it also gets rid of the connector footprint at the rear by housing them inside the smaller compartment on top. When you factor that in, the footprint is *FAR* smaller than any of the other cases listed above.
That's what I like about the FT03 so far. Lots of pros but the only con for me is that he hard drive has no air flowing for it so it should get warm there no? Between the Lian Li PC-V354 or Silverstone FT03 which can put a bigger heatsink or high end air cooler like a Thermalright Silver arrow?
are you a professional photographer? those are great photos!
No, I'm not, but thanks! :)
My 3 HDDs are around 50C, so not too bad. It does get passively cooled somewhat by the panels since they are relatively thick. Not sure about a silver arrow as that's pretty big, but the FT03 definitely has a lot more room for a high end tower heatsink compared to the V354. I was looking to get the Thermalright HR02 and that has been shown to fit easily in the FT03.
