Dapperdan
- Jun 17, 2002
Work related, mainly small web server with a VNC server allowing 50+ people to connect to at once
$2000
US, Il
I need everything, CPU (i7), Motherboard, Ram (12+ gigs), video cards and everything else. A key aspect is I need 3 video cards with a supporting mobo. Going to be running 6 monitors (technically 5 virtual monitors). The last similar system I built a few yrs ago the 3 video cards didnt fit, I need a proper suggestion on the 3 video cards that will fit with what ever mobo suggested
6) Will you be overclocking?
No
Max res I can get
Now
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Top features if possible, not sure if all will be used but would like to have the options there.
Win 7 64
$2000
US, Il
No
Max res I can get
Now
Win 7 64
