need a lil help w p3....
MAngelo
In a Dell box. The 256mb stick of pc133 died, and several sticks I've bought locally don't seem to want to work. The last one I bought today was a single sided stick of pc133 and no go. The cpu is a Intel 933mhz p3.
Does anyone make a socket 370 mobo for this chip that uses DDR instead of SDR ??
I have pc2100 and pc2700 laying around, and pc133 is getting expensive, not to mention the compatibility.
Thanks,
Mike
The only P3 boards I have seen that use anything other than PC133 are a few dual boards that use PC800 Rambus. If I am wrong someone please correct me.
The Dell shouldn't be using anything funny on the memory. If you can tell what brand it had in it before try finding a match to it.
That's strange..
I'm willing to bet that you just got a bad stick. Try the FS/FT forums, they will get you a good deal of PC133 :)
USMC2Hard4U said:
Maybe your DIMM slot died.
I agree. There's no way that all those different sticks are all bad or incompatible. I've never had compatibility issues with PC133 memory.
thanks for all the replies guys. The most recent stick I grabbed today from a local shop is a generic with Samsung chips- a 256mb pc133-single sided- a similar 512mb stick failed too. I have it booted currently with a single 64mb stick, also single sided, pc100, Hyundai chips.
thanks again for the help/replies. :)
edit: gawrsh WindersXP runs slow w only 64mb ram :D
pulled a stick out of another working dell- its a Kingston stick labeled KTD-OPGX1N/256
it runs fine in either machine, either slot
its also double sided
does single sided vs double sided make a difference in ram compatibilty ??
thx again all
You might need a Bios update to run more than 128mb sticks? Seems like a stretch though since I'm pretty sure they were running at least 256mb sticks when they came out.
Good call, that may be it. I remember my P3 500 not being able to run a stick of 512.. but a 256 seems like it would work? :confused:
OK, FWIW, problem solved. Looking at the box on a stick of pc100/133 at CC, I read the back for compatibility. KVR-133q/256mb (pc100/133 compatible for all p3, p2 350,mhz and up)
YAY pc's ok- it gets sold now. :D
thanks to all who replied.
