- Feb 16, 2003
So I won a contest a while back (6+mo ago), Gigabyte Z590 Aorus Pro AX, with an 11400 CPU and 32GB DDR4 and a PSU
I'm ready to put this thing inside a case but I'm really not sure what's out there that fits my criteria
Namely: Supports 2x 240x30mm radiators, 190mm PSU, full size Nvidia GPU (it'll have a block on it, which should reduce the size), as well as enough space to build a custom loop inside
But I want the highest quality case possible while also being very small. I don't want a full size ATX behemoth.
I saw the ssupd meshroom s, which seemed to be a little too small (2x rads aren't possible with my mobo, and the PSU I have won't fit)
Any ideas?
I'm leaning towards the Lian LI O11 Evo, but I'm not a fan of glass panels. the available front distro plate is tempting though
Any advice or suggestions is appreciated
Any ideas?
