Need a board for a Turion MT37
Treyshadow
I need a board for this processor. It is socket 754 and I cannot get it to work properly in a Biostar 6100-M7. I have gotten 2 other processors to work in the same board, without issue, so I know its not the board.
I have gotten the processor up and into windows, but it won't reboot properly as I have to reset the cmos to get it back up again after a shutdown. So.... I am looking for a good board to put this in. I was thinking of getting the TForce board, but hell I have AGP cards and such just laying around. I was wondering what others have used with turion processors and their success rate.
Thanks
You got the board to work with two other Turion processors or just two other processors?
Yes I have the latest bios, I had it sent to me from biostar-usa. I am using 24
Anywho, I got it to work with 2 other processors, no other turions.
1 A64 3400+ Clawhammer (original) 2.2 GHz
1 A64 Sempron 2800+ which is currently doing 300x8 at stock volts in that board
I can get the board to boot 1 time at 4x200 (safemode from the bios. It will say AMD MT37 Turion on the screen, so it spots the processor, I can get into windows, and do whatever, but only at 800 Mhz. That is no good. I can't reboot, it will not make it back into windows. I can't change the bios settings, it won't make it into windows. I was able to install windows with this chip, I just had to reset the cmos at any and every reboot. Of course it did it at 200x4 = 800 Mhz.
I would ask them if they have a bios available specifically that supports Turion processors. I'm pretty sure the DFI does, but that's the only one I've seen.
