The spec sheet says it can go up to 85hz which is the highest I've ever seen on a 60hz LCD. Wonder if it can do true 85hz.
TFT Central review is up:
http://www.tftcentral.co.uk/reviews/nec_p241w.htm
Not sure how they managed to acquire one.
Hmmm, looks like the input lag is pretty bad.I'll have to read the whole thing more closely. Probably a pass for me.
Well it is a professional level monitor with gaming really not in mind as its general purpose. But it would have been nice if it wasn't so high.
The NEC panels are too bright (for people who like low brightness) without loosing CR![]()
Those input lag measurements are wrong, wait for Prad to test it for the real values.
not sure which model you are referring to, but the P241W seems to be able to get down to ~100 cd/m2 without sacrificing contrast ratio - ie through adjustment of the backlight intensity only. After this, lower luminance is available but only at the cost of CR through digital level adjustments
no A-TW polarizer on any of their new PA / P models
Unfortunately both these screens are wide gamut, not good for my purposes.HP LP2480ZX and LG W2420R.
