Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Hey, I have a NEC MultiSync 1810 LCD, and when I turn it on a picture shows for about a second and then shuts off. Anyone know what's wrong, and if so how it can be fixed?
At every resolution change it will display for about 2 seconds the go black (not just black but like off black). So at post there is a 2 second image, then black. Then at the OS splash screen I get 2 more seconds and again at the desktop resolution.
Of course it is out of warrantee so so cheap and easy repair.
Is there something I can just replace and recirculate this LCD?
I did some research and it seems like people said it was either the lamp or lamp inverter. I'm guessing however it's the lamp inverter since it does show a picture and then goes out. As for where to get one, I have no idea. Lemme know if you find any new info.
cool, if you need help PM me or send me an email to abcheng at earthlink dot net. I've already taken the thing apart and I know exactly where the inverter is.
