Edit: The issue I'm having has changed, and I'm bringing this thread back up because I haven't found a solution yet. My current problem is that my computer doesn't recognize the LCD2490WUXI when it's in HDCP mode, which makes it impossible to watch BluRays--one of the main reason I bought the monitor. If anyone has any experience with or suggestions on this issue I'd love to hear from them. Thanks!
Original Post:
Original Post:
I'm having an issue with my newly purchased refurb NEC LCD2490WUXI that I was hoping to find some help with. When I got it it worked ok with my laptop via VGA, though I only had the option to set the resolution up to 1600x1200. I connected it to my old desktop computer via DVI and still couldn't set it all the way at its maximum resolution, though I don't remember what the maximum allowed resolution was. I fixed this issue by selecting the option in display settings to decrease the frequency of DVI output for high resolutions. After doing this, I could choose resolutions up to 1920x1440. I selected 1920x1200 and it worked perfectly. I then connected the display to my laptop with an HDMI to DVI cable. The default resolution was 1050x1680, but I had the option to turn it up to 1920x1200 and did. The problem then became that the image was shaky. It became shakier the more I increased the resolution, but the effect never completely went away even when I made the resolution very low.
So here's where I'm at now. I reset the laptop in my attempt to get rid of the shakiness, and when I turned it back on, the monitor was no longer being detected. I purchased a second HDMI to DVI cable to find out if the cable was the issue, and that didn't fix the problem. I then connected it to my laptop via VGA again and the monitor still wasn't being detected. Finally, I connected it to the destop again via DVI and the desktop is now not detecting it either. The monitor is not being detected by either computer on any input. Oddly, though, the monitor works perfectly well when connected to a DVD player using either of the HDMI to DVI cables.
The laptop is an HP Envy 17 with an ATI Radeon M5850, and the desktop is an old Sony with, I believe, an ATI X300 graphics card.
Any advice would be greatly appreciated.
