NEC LCD2490WUXi Defect or "Feature"?
Discussion in 'Displays' started by IgiVeUp, Jul 19, 2008.
  1. IgiVeUp
    IgiVeUp n00b
    11
    Jul 19, 2008
    First of all, hello to the members of this forum. I've been reading for a while, but now I'm in a situation where I'm seeking advice and I hope you can help.
    I got some strange, mostly vertical, streaks on my display. Unfortunately my P&S camera wasn't able to capture this properly, but if you have a close look at the following picture you will notice it. The most visible streaks I marked with a red dot. Move your head from side to side or move the picture for a better view.
    http://forum.planten.de/galerie/d/119627-2/crap.jpg
    --- update:
    this picture should be better:
    http://forum.planten.de/galerie/d/119732-2/crap+II.jpg
    Go upwards from where the mouse pointer is located. (don't worry the finer grid lines - this is just an effect of taking the photo)
    Can you 2490 users please tell me if you got the same effect on your displays? Is this a defect or a feature of this monitor?
    Info:
    - brand new June '08 Model Rev. 2D, calibrated with included SV
    - same effect with both ColorComp switched on/off
    - same effect on both DVI inputs
    - effect visible on all colors
    - reference monitor running in clone mode is not affected
    - already tried different cables and VGA outputs
    regards
    IgiVeUp
  2. Majed
    Majed [H]Lite
    102
    Jun 26, 2007
    Yeah,
    I can see it if i use the regular photoview program instead of seeing it inside the browser.
    i think it's no way this is a Feature!
    I have SV 2690 btw.
  3. Biges
    Biges [H]ard|Gawd
    1,475
    Feb 28, 2008
    Good idea to post a photo :)
    If it is what I see, then you should contact the NEC tech support.
  4. 10e
    10e 2[H]4U
    3,385
    Jul 20, 2006
    Yeah there is definitely something funny with that photo. It seems like a strong backlight inconsistency.
    NEC may recommend you run the monitor at 100% brightness for a bit of time, but I would call them up and see what they think.
    My 2690 doesn't do anything like that especially with blue background.
  5. IgiVeUp
    IgiVeUp n00b
    11
    Jul 19, 2008
    Thank you people for having a look at the photo.
    This is pretty frustrating as it took me a lot of effort, time and $$ to get it shiped overseas.
    btw no 2490 users around?
  6. TechStuey05
    TechStuey05 Gawd
    899
    Aug 5, 2005
    I own an Nec 2490 and do not notice any defect like your photo showed.
  7. Biges
    Biges [H]ard|Gawd
    1,475
    Feb 28, 2008
    Where are you from, if I may ask?
    I'm from Europe, so no other choice than to buy 2690, no 2490 here.
  8. PAo_ReVoLT
    PAo_ReVoLT [H]ard|Gawd
    2,036
    Apr 4, 2008
    i had 2 2490s non of them like that (is the spiral thingy you are talking about?)
  9. IgiVeUp
    IgiVeUp n00b
    11
    Jul 19, 2008
    I'm from Europe too, so I got it shiped from the states
    No. Try your photo viewer application to watch it in fullscreen instead of using your browser.
  10. Biges
    Biges [H]ard|Gawd
    1,475
    Feb 28, 2008
    I which I was brave enough to do what you did. But in the end, I'm happy with that 1,5" inch extra. Anyway, depending in which country you actually live, I think local NEC may be willing to give you a helping hand. They are one company after all.
  11. IgiVeUp
    IgiVeUp n00b
    11
    Jul 19, 2008
    This product is highly recommended almost everywhere, so it wasn't a tough decission for me. But right now I feel a bit brave :confused:
    Currently I am in contact with local & US support as well as my reseller. I hope I can get a replacement without too much hassle.
    I would have gone for a 2690 too. But currently I have little use for a wide gamut display. It is a sad story NEC Europe doesn't sell the little WUXi.
  12. IgiVeUp
    IgiVeUp n00b
    11
    Jul 19, 2008
    added better photo - see post #1
  13. visualguy
    visualguy Limp Gawd
    257
    Apr 7, 2007
  14. IgiVeUp
    IgiVeUp n00b
    11
    Jul 19, 2008
    Thank you very much for this information visualguy. Yeah, this looks pretty familiar to me. It's not that bad here though.
    I'll buy you all a virtual drink if I get the same service
  15. chubby bunny
    chubby bunny Limp Gawd
    280
    Jul 8, 2006
    Just figured I'd be the 100th person to let you know that I'm able to see it :D Hopefully everything works out for you man.
  16. IgiVeUp
    IgiVeUp n00b
    11
    Jul 19, 2008
    Thanks for support chubby.
