NEC 23" IPS EA231WMi
I must say, even though I love this display, it seems so much smaller then the 1920x1200 24" FHD2401 that I originally bought. I'm really going to have to get used to 16x9...
When doing the color uniformity tests, what level should the brightness be adjusted to? Are there any other setting, like contrast, that should be adjusted as well?
I don't think it makes much difference, excluding extreme settings. Defaults (50/50) are fine.
man this is really unfair, american always get the best deal! I still can't decide between this or the HP LP2475W. I am not sure about the 14ms respones time....it seems quite high. Any idea how this monitor is like in gaming compare to LP2475W or the Dell U2410? Just like most people here I want the best over-all monitor for everything from gaming to web to movies (maybe not soo much web design) . So do you guys recommand this monitor? Or should I just look for a good TN (if that exist) or S-PVA panels monitor? thanks
I have absolutely no idea what people mean by input lag, this monitor looks great when playing games.
Ok. Here are my last color uniformity tests. 2 different greys (one is 128R,128G,128B), a white, and black. What do y'all think?
I haven't done any serious gaming with this monitor, but there was no ghosting with any of the several moveis I've watched on it. I doubt the LP2475 or U2410 would be noticeably different in terms of response time; maybe a ms or two. I'll get back to you when I've gotten back to school and really put it through its paces on my desktop.
Input lag is the time different between the image signal going in the monitor and the monitor displaying the image. For example in gaming (if the input lag is 0) there will be no delay between me moving my mouse in real life, and me seeing the mouse move on the screen. The higher the input lag, the bigger this delay will be. In games like FPS 60ms input lag could make alot of different. Anyway I got carried away lol I am not talking about input lag here, EA231WMi has a pretty low input lag. I was talking about respones time which is like the time it takes from a pixel to change its colour (i.e from white to black). If a monitor have high respones time (some would say 14ms is high) you will start to see a shadow, faded, blur image when things move fast on the screen. You can see an example here: http://www.behardware.com/articles/629-6/24-inches-the-dell-2407wfp-vs-the-samsung-244t.html
Iits pretty good I think, but i can see quite abit of backlight leakage in the corners (quite common in EA231WMi i thinik, which is abit disapointing) but if it doesn't disturb your normal use then its all good.
Yeah, the backlight leakage is quite disturbing from the photo. However, its not that bad when viewed with the naked eye. The blueish hotspot is a bit noticeable during movie playback, but I think I can deal with it because its not distracting, just not "ideal/perfect". I'm very, very picky. But aside from the uniformity and backlight, this monitor is shaping up to be pretty darn nice. Still gotta give it the hard look for dead pixels and watch a blu-ray movie (waiting for an HDMI to DVI cable), before I can say that it's a keeper.
After having my display for a day now and taking a few pics is that they pics make the backlight leakage look MUCH worse then it really is. I absolutely despise backlight leakage and this display doesn't bother me in the lease.
Hey, long time quiet reader here. I just want to say thank you for your contributions, after reading for a couple months I decided to get this display based mostly on the comments here and after a few days using it I can say I'm very happy with my purchase, I agree with duder1234 and criccio about the uniformity being the weakest point, and even so this is subtle enough to don't bother me, I consider myself picky too and I'm very satisfied with this display, it isn't perfect but it has excellent colors and nice sharpness and I think it's definitely an excellent value at this price.
Well, couldn't find any dead pixels using multiple colors and angles. Wheeeeww! I also want to give one last thanks to those that have contributed to this thread. I almost gave up looking for a monitor (having previously returned a Samsung 2494HM and looking/reading about a crap load of other monitors), until I stumbled upon this little gem of a thread. Thanks again. I'll probably throw up mine own review/contribution once I watch a blu-ray movie. Until then...
For some reason, I cant figure out how to change the screen to portrait mode. Does the monitor change to portrait mode when flipped or do you have to change a setting in the OSD menu and then flip?
I do it in CCC. Nvidia CP should work as well.
Guys, WHat do you use to hook up a third monitor?
If you have one GPU with 2 DVI ports, you need a second GPU.
Or.
A single 5000 series ATI GPU and at least 1 monitor with a DisplayPort connector.
Or.
A single 5000 series ATI GPU and a DisplayPort to DVI adapter.
I don't mean to get off topic, it just goes with getting this monitor and using my current 2nd monitor as a third. I have a good card with 2 dvi out. Saw the ATI 5 series with eyefinity, might upgrade but also saw the USB one and might do that due to usage will only be internet stuff. EVGA makes ausb device. Man, I love tech stuff and use to keep up on it alot, but have 2 young ones and ones ad 50 hour work weeks just leaves little time to research more; although I am researching. I emailed NEC for the release date of the new 24" will report if they let me know!
http://www.amazon.com/EVGA-100-U2-UV16-A1-Supporting-1600x1200-Resolution/dp/B00191GZ8U/ref=sr_1_3?ie=UTF8&s=electronics&qid=1263155319&sr=1-3
I'm thinking about buying this monitor and was wondering if anyone here has managed to get 83hz working with DisplayPort, Windows 7 64-bit, and an ATI 5XXX card?
These are the timing parameters I used to get 74.6 Hz at 1080p:
Horizontal active: 1920
Horizontal front porch: 25
Horizontal sync width: 35
Horizontal back porch: 45
Horizontal total: 2025
Vertical active: 1080
Vertical front porch: 3
Vertical sync width: 4
Vertical back porch: 5
Vertical total: 1092
You can also use those settings to do 72 Hz at 1080p.
i made these setting changes in powerstrip but i don't see where to set the refresh rate :confused:
Ordered it today via Buy.com, now just need to figure out how to do a third monitor,
1) add a inexpensive video card
2) Add the ATI display port card
3)Use a USB device for the 3rd monitor (not gaming or movies just daily routine stuff/internet
The easiest/cheapest option by far is just getting another inexpensive GPU. An ATI 3450 can be had for $35 brand new on newegg.
THanks, thats what I may do then, Will look, the problem with neweggg is that I find more than I need :eek:)
When you set those settings, the refresh rate is then determined by the pixel clock. This may help you find the pixel clock you want if you know what refresh rate you're aiming for:
http://www.tkk.fi/Misc/Electronics/faq/vga2rgb/calc.html
For example, enter all of the info (front porch 25, etc), and set the pixel clock to 165mhz for 74.6hz.
I just got my 231WMi from Buy.com and love it, except for one issue: I have a stuck green pixel near the center of the screen.
I tried the JScreenFix program for about an hour and some gentle massage/tapping with no change. I have a feeling that contacting NEC customer support would be worthless, and I'm not sure if Buy.com would send me a replacement if I classify it as "defective".
Any recommendations on a possible solution? Or am I just going to have to live with it?
Quick question, does the supported monitor driver lower resolutions offer any that maintain the 16:9 aspect ratio?
it's OK so far.
Good looking monitor but next to my 2490, not so good. text is fuzzy and colors different. I will mostly be using for text/internet. the text is not crisp and colors not solid; rainbowish. I was told to update my video card and should help. any thoughts??
Also, I called NEC, the new pa series 24" is coming out February 1st. The 23" version is slated for SummerTime!
I've been playing with the menu options and now have better looking text and not so bright monitor
I'm getting better result after taking itff that DVI mode and poutting it in 8500 mode and adjusting some colors. od. much better now and not so bright. strained my eyes for 2 hours.
You gave that opinion without calibrating it??
Buy.com has it for $305 free shipping. Last time they had it this low it last for less than 24 hours so you may want to jump on it if you've been sitting on the fence.
I just ordered ordered mine from Sparco.com for $300 shipped. I took advantage of their price matching policy, so I saved $15 compared to Provantage ($295.58+$19.45 shipping fee).
Incidentally, Dell has begun shipping the updated "A01" firmware with new U2410 monitors.
Regards,
Brian
