I have seen numerous posts for the Nec 20WMGX2 and I just wanted to know if anyone else is having image persistence issues with this monitor. Basically, an image remains in the display's background after I minimize or close a window, and this will occur only after 15-30 minutes (not hours or days for typical "burn-in" effect), and it typically goes away after the same amount of time. I had to RMA two of these monitors now with Nec because the image persistence was too noticeable to ignore, and the possibility of the problem getting worse. Fortunately, the second monitor went directly to the engineers where they are going to look into this problem more thoroughly. Other than that, this monitor has a beautiful display.
If you do own this model, try using a solid color background (not too dark) and leave an application window open for 20-30 minutes, and then minimize it to see if it leaves an image in the background.
