So I'm having trouble finding the right screws to use for my NCASE M1 radiator. The problem is I can't find radiator screws that have a purely flat head with no countersunk bottom. I need it flat so that the magnetic filter that comes with the case sits flush against the radiator fans (if the screw heads are rounded then not all the air goes through the filter). And I don't want countersunk flat head screws because that metal bracket that the radiator is attached to wasn't made for countersunk screws and the radiator won't be completely secured. The display case on the website has the right screw heads that I need. And they didn't come with the case. Here's a pic.
So basically I'm looking for #6-32 1-1/4 inch screws with a flat head and flat base. And I'm flustered because I can't find what I'm looking for. Please help me out guys.
