I don't know if this applies to the sfx psu bracket, but would it be possible to design the psu bracket(s) to be removable from the top? like somehow having it slide out vertically? currently it appears the only way to remove the psu is to disassemble most of the other components.
What you're asking for, essentially, is a change to the design that makes a bunch of compromises to accommodate your specific edge case, when there's a simple solution available to you: use a PSU that the case was designed for.
Agree about having the option for other orientations of angled connectors, or at least if we could know the source manufacturer to order custom C13 extender cords.
(I wonder whether the entire component orientation in the case could be flipped upside down so that the exhaust side of the power supply, with the power switch and C14 plug, would abut the bottom of the case.
I remember back then people wanted a 2 gpu slot instead of three. Making the ncase m1 shorter. Just my suggestion.
It would be interesting to know how many ncase owners are running mDTX boards and using all three slots. My suggestion for r2 is to force all buyers to sign a petition for more mDTX motherboards
First of all, I'm very pleased with the case. Very well thought-out. I was able to mount my 2.5" SSD, 2 RAIDed 3.5" drives, and a 92mm water-cooling system without any problem.
- Minor issue is that I find the Power cable/extension is too long, requiring me to 'loop' it to fit properly. Also, perhaps a way could be found to make the connector reversible/universal? i.e. including a replaceable connector head so you could plug it into the Power Supply in either direction (v or ^) without having to twist the cable. Might not be practical, but just thinking out-loud.
- Also, the all-rubber pass-through bushings on the back of the case are a bit shoddy in quality and don't stay on well. Perhaps sturdier, snap-in options could be used in the future.
- The other issue I encountered (which may or may not be a design issue) related to the Optical drive mount. I purchased a slot-loading laptop Blu-ray drive (UJ-235) and installed it on the M1, but found that the drive simply could not read disks in a vertical position. I also tried another drive, with no success. This forced me to mount the drive in an external caddy, which defeats the purpose of having the mount and slot cut in the case. Perhaps a horizontal mounting option for the optical drive can be accommodated in a future design? - In the meantime, does anyone have a solution (perhaps a different brand of Blu-ray drive I could buy that does read disks in the vertical position?)
Thanks, and keep up the good work!
Somewhere else in this thread other people were having issues with the drive reading discs. I believe the issue is that some screw was over-tightened and that reliving some of the tension made everything function properly
My only suggestions are cosmetic. Remove the top panel screw and offer more colors assuming MOQ is met - tell everyone they are only guaranteed silver or black, but that they can request a different color and if enough people request it, it gets ordered.
The option to buy panel kits (maybe that is the only way to get a different color)
+1, I would also like to be able to install/remove my SFX from the top, or even from the back, if possible.
I don't mind removing the side rack, but getting the PSU and bracket around my cooler is a pain in the ass.
It'd be convenient, but realistically I don't think it's doable. The SFX bracket would need the support attached to the motherboard removed, leaving it supported at three points. Plus the flanges around the top of the case are in the way, and I'm extending the front flange a few mm to address another issue. There just isn't a good way to do it in the case as-is.I think that is a good suggestion, I've also had difficulty getting the PSU in and out because of this. It would be nice if this indeed was possible to remove vertically.
Yes, I understood your earlier post. The point is that when using the recommended hardware (note that ATX PSUs, while possible, are explicitly not recommended), the included cable is sufficient. Yes, we did specifically go out of our way to use the lowest-profile angle connector we could get for the case - one which, unfortunately, is not commonly available. Every reasonable measure was taken to reduce the size of the case, but that also means there will occasionally be incompatibilities. As evidenced by the number of successful builds, however, the included cable is adequate for the great majority.Hi Necere:
I see that I did not articulate the issue that I raised in my earlier post (74) very well. I believe that the issue regarding height clearance between the top of the power supply and top of the case exists for all users of the case—regardless of whether they are using an SFX or ATX power supply.
But if you did that, you'd give up:I remember back then people wanted a 2 gpu slot instead of three. Making the ncase m1 shorter. Just my suggestion.
I think the most important thing you didn't mention is the PSU would be exhausting into the case. Not something you want to do.There was a time I was exploring the possibility of somehow modding my psu so i could attach it to the existing psu bracket but have it flipped upside down.
two things that stopped me was I realized that if I were to flip the psu around, I'd probably need a longer power cable. And since it was a proprietary length that would mean I'd have to cut my own, which I had no experience doing. But the main issue was that the height at the top of the case would not be enough to accommodate the modular plugs. By my rough estimation I'd actually would need appx 11-12mm more height, So even if I were to mod the psu in such a way to flip it, and get a custom power cable, ultimately I'd not have enough room at the top.
A slim one, maybe. Definitely not enough for a normal 25mm thick fan. Regardless, a height increase is not on the table at this time.Although, hypothetically If there were an added 11mm in height, would that be enough space to allow mounting a 120mm fan on the top?
I had a discussion about something like this early in development. It's kind of a neat idea, but I don't think it's workable - partly for technical reasons (it needs to be a flexible riser, but likely won't be flexible enough to put so close to the board/slot, or will stick out too far in one direction or another), as well as economic (cost/MOQ). For something most people are unlikely to take advantage of anyway, it just doesn't make a lot of sense to pursue it.b) Would it be possible to source a pci-e extender (sort of a riser, but its not a riser because you are just moving it a slot away)? Why? If we could move the GPU one slot down (without moving anything else)... there would be more space to use an ATX psu, and thus the case would gain flexibility. It would also make it easier to install a waterblock on it, I guess.
I think what we may do is to see if the supplier can get us a left-angle version of the connector/cable, which we could potentially offer for sale on the website.
Do you have a link to a tutorial how you did that? It looks very clean.It's actually not that hard to "fix" the length of the PSU cable, the only skills needed are being patient and be able to solder. The wires are very easy to shorten.
Yeah, seems simple enough.. but you've never seen my soldering skills
I'm sorry but soldering two wires together and then heat shrinking over them has got to be one of the easiest things I've ever taught myself.
Good catch. I can lower the drive cage, but not by much before it runs into the top of the GPU. Think 2mm will cut it?This is regarding the additional notch in the HDD cage so that the fan bracket can fit the upper slot.
I dremeled a notch in the HDD cage, and found that the HDDs are too close to the top of the case, such that my connectors are touching the top panel. The top panel catch that is near the HDD still locks but not completely, and the top panel is not aligned with the side panel. The sata power connectors are from my silverstone bronze psu, the sata cables are obviously right-angle ones.
Just a heads up.
As vipz said, extra-wide cards like the Classifieds won't fit. See this post. But as far as length, the case will handle up to 12" cards.As someone who woke up early to purchase one of the extra M1s but missed out (I recently moved to a new timezone and wasn't thinking when I set my alarm, so unfortunately I was an hour late), I'm super excited for the Rev2.
Things I care about:
Everything else you mentioned is already in the design, and the changes are only minor things for rev 2. The only thing that might not work (you didn't explicitly mention it, but it could be inferred from what you said) would be if you wanted to do two separate AIO liquid coolers for the CPU and GPU. It *might* fit if you really cram things, but I wouldn't want to. If watercooling the CPU+GPU really the best way is to use a 240 rad and do a custom loop.
From our site:Additional questions:
- Would the classified card fit in the M1 if the power connectors weren't hooked up?
Max length: 12.5" (slots 1 & 2), 11" (slot 3)
Max width:
-For cards up to 11.5" in the first or second slot: 5.5" (4.7" at the PCIe power connectors)
-For cards up to 12.5" or cards in the third slot: 4.4"
From our site:
Newegg says the GTX 680 Classified is 5.94" (151mm) wide; if that's accurate, then no, it won't fit - power connectors or not. Keep in mind the entire case is only 160mm wide.
First I've heard of (or heard) whistling. Are you running the fans at fairly high speed (>2k RPM)? Have you tried running with the side panel off to see if it's actually a result of the vent holes? I read an analysis of the impact of different vents designs some time ago, and IIRC the uniformly distributed smaller holes like we're using was one of the quieter ones (albeit somewhat restrictive).Would it be possible to make the vent holes on the panels larger? I find that there is noticeable amount of "whistling noise" being made when fans up against the vent are pushing a lot of air through. Maybe larger vent holes would prevent this? Also, having larger vent holes would make using vinyl wraps on the panels a much more feasible task (something I wanted to do but decided against once I saw how small the vent holes were).
This has been brought up before. The HDD mount can't be moved forward without giving up the bottom fan mounts, basically. A separate bracket that attaches to the fan mounts might be a possibility, though there's little vertical space to make that work.Also, with the original M1 I'm forced to not have my HDD on the bottom of the case as my GTX 780 (reference blower) spikes my HDD's temp to ~55C when gaming. Given that the GPU's heatsink is right above where the HDD is when installed on the bottom, I'm wondering if being able to install the HDD closer to the front end of the bottom side of the case might prevent the heat radiating from the card from baking the HDD.
