Hi guys!
What do you thing about EK-KIT s360 and their additional GPU expanding component for it?
Thanks for your input.
It's a decent little starter kit, you do realize that a 360mm radiator won't fit in the M1?
NCASE Tracking Update!
My build is finally done!
Just missing my acrylic window which is on its way
OMG thank you rfarmer, my bad. I was about EK-KIT S120. Fixed.
WOW…!
VERY nice build…!!!
Now I am going to have to demand build specs & temps (ranging from idle to full load on both CPU & GPU)…!!!
Is that a Hardware Labs 92mm radiator on the back exhaust there…?!?
Seriously, this is a REALLY nice build…!
Very nice Sebbie! What Hardware are u using and which temps to you get?
Thanks!!! I will go for watercooling in the next few weeks, but till now i´m not sure if i use the radiator on the bottom or on the side...
What direction are the fans running…? Blowing out, or sucking in…?
Are you running the sound daughter card on the M7I…?
Would you think there is room to access the U.2 port in such a config as yours if the MB was the M8I…?
Any pics of the build-up itself…?
Attachment/mounting of the pump/res comb…?
Details on the windowed side panel & attachment methods (once you get the actual window in)…
Again, AWESOME build…! SO much water cooling goodness, all crammed in the (relatively) tiny M1 chassis, but right there for the whole world to see…!
Damnit…! Now I want to build a full-on water cooled M1 gaming rig again…!
But that would totally be blowing up the budget…
/sadface
/gnerdrage
Sebbie.... SWEET!! Must have been fingers at strange angles going on to get all that in there...My build is finally done!
Sebbie.... SWEET!! Must have been fingers at strange angles going on to get all that in there...Funny, how to me, it looks rather retro 'Back To The Future'-ish !
I have both the Corsair H100iV1 and the H100iV2 AIO's coming....
I have read that the original Corsair's (V1) hoses are more flexible than the V2's ones, which would help me in my upcoming (next week) build with the M1 case and an Asus Z170I Pro Gaming MB. However, other posts have said the H100iV2's CPU block more easily fits more Asus MB's than the original..... HMM.......
What do you folks think?
Both can work well, it just depends on what other parts you're using and what your priorities are.
I should note that the H100i v2 is the same as the H100i GTX (for fitment purposes, at least), and it's not a good fit for the M1 due to the lack of swivel barbs on the pump, and long/stiff tubing. The original H100i or any number of other Asetek-based AIOs from other manufacturers are a better choice.
The 120 would be fine if you were just cooling your cpu, if you plan on adding the gpu in the loop I would look at EK-Kit S240
Qrash...
Thanks for info. I guess I can't keep up with all these posts on all the different issues of everyone's individual builds. (Thought I remembered Necere's post, but wasn't sure)
So, I'll keep the Corsair H100iV1 as my AIO cooler and return the newer V2. (Although, I think someone at Anand forums said the V1 of that Corsair H100 AIO is somewhat of a tough fit on some Asus MB's...)
I'm thinking I'll have the M1 case next week sometime, and then I can start the new build. (preparing psychologically... for gnashing of teeth and swearing...not as good as you guys at this stuff).
That looks like a NH-U9S CPU cooler. Is there room on the side panel for a 14cm fan with that CPU cooler, or only a 12cm?
Hi rfarmer,
Many thanks for your suggestion. My M1 on it’s way and most likely next week I’ll receive it. This time I’m going with GTX 1080 and i6700 and concerning if EK-KIT S240 can handle both of em? Or better stick with air cooling to avoid experiments? I appreciate your opinion.
Best
Update on my FrozenQ status.
It took them THREE weeks to ship from ordering. When I ordered there were 8 in stock according to the website. My order was "processing" for two. I asked politely via email (they dont have any phone contact), what the staus was. Never heard back. Filed paypal claim, that got them semi-interested, was promised that there were a lot of orders from the recent NCASE batch, and it would ship on monday. Fine. I got a tracking number that monday, however NOTHING shipped. Asked again, whats up. Nothing. Escalated claim. It shipped two days ago under the same tracking #.
TL;DR. Avoid buying a frozenQ res if you can.
Hello!
Is it possible to get hold of an 3d model of the m1?
I'm already the lucky owner of the case and are in the planning stages of what to put in there.
a 3D model could help me figure out what GPU I can squeeze in there
really looking forward to build this.
Thanks!
Take your time and plan ahead. I must have removed compnents several times the first time I built in the M1 because they were blocking something or other. My suggested build order (primarlity for an air cooling build) is:
Well, I'm sure it's not perfect, but I hope it helps!
- Strip the M1, removing all panels, the drive cage, and the side bracket. Keep
- Open the accessories box and organize the mounting screws, grommets, brackets, and everything else as per the photo on the Ncase website in the FAQ tab.
- If using the drive cage, prepare it by mounting the drives into it with the appropriate screws and grommets.
- If using 2.5 inch drives attach the necessary mounting screws and grommets. Use the stacking brackets if you want to attach two drives together. If they will be mounted on the outside of the frame's front panel, both drives must be 7 mm or less in height (thickness?). Taller (thicker?) 2.5 inch drives can be combined and mounted inside the front panel, but be aware of the distance to the adjacent power supply.
- If using an optical drive: remove the two brackets on the front panel and attach them to the sides of the drive. (Those screws are tiny!). Don't attach this drive to the frame until the end. It's easy and leaving it off can make other tasks easier.
- Install the CPU into the socket on the motherboard.
- Attach any mounting brackets for the CPU cooler to the motherboard. I don't know if liquid cooling CPU blocks or AIO block-pump devices should be attached at this point or later when the motherboard is in the M1 frame. Sorry.
- Install RAM onto the motherboard.
- If there are daughterboards or cards with wires, such as a Wi-Fi or Bluetooth, that need routing around motherboard components or under the motherboard itself, attach those to the motherboard and route any wires while the motherboard is still outside the M1 frame.
- Install any other components that attach or mount to the motherboard, such as M.2 or mSATA devices.
- Install any bottom fans or a single 3.5 inch drive to the bottom of the M1 frame Attach cables to the single 3.5 inch drive before mounting it to the frame.
- Consider moving the external power socket at the top of the rear panel from the corner position to the center position. This can be helpful with some large CPU air coolers or when there is a radiator and fan on the rear position of the side bracket.
- Install the I/O Shield into the M1 frame (so easy to forget) and then install the motherboard into the M1. Attach any Wi-Fi/Bluetooth cables to the I/O Shield.
- Install the power supply adapter frame.
- Connect modular power supply, data cables, and Front I/O cables to the motherboard. The power supply end of modular PS cables are easy to attach to the PS unit so leave that until later, but route the cable towards the front of the case where the PS unit will be..
- Practice and finalize fan placement and connect fan cables to the motherboard headers. Let the fans hang outside the M1 frame, except for the rear panel fan, if you plan to use one (mount that one now) and any bottom fans (should already be attached). Use fan splitters and extension cables where appropriate or necessary, such as for bottom fans, dual CPU cooler or radiator fans or to reach the front side bracket location. These can make disassembly (for cleaning or repair) easier in the future. Side bracket fans, either alone or attached to a radiator should also be hanging loose around the M1 frame for now.
- Install SFX power supplies to the adapter frame.
- Install hard drive(s) to the inside of the front panel or the side cage. Attach their data and power cables.
- Install ATX power supply to the adapter frame.
- Connect modular PS cables to the power supply unit, including any PCI-E power cables for the graphics card.
- Install the CPU air cooler heatsink. Attach fans first if it is not possible to attach them after the heatsink is mounted. For the NH-C14 it is possible to slide the bottom fan in from the top of the case, even if the motherboard has a tall power daughterboard along that edge, like some Asus models do. Attach any remaining cooler fans to the heatsink.
- Attach any drives (2.5 inch or optical) to the outside of the frame's front panel and attach their data and power cables.
- Remove the small rectangular metal plate above the expansion card slot covers and then remove the slot covers where the graphics card will be located (usually the top one or two slots).
- Install the graphics card into the case and attach the PCI-E power cables. Re-attach the small plate above the expansion slots.
- Attach side fans or radiator and fans to the case's side bracket and attach the bracket to the case. Obviously, flexible hoses for liquid cooling must be carefully arranged to avoid kinking when the side bracket is attached.
- Attach all of the exterior case panels.
Wow, thanks so much for all that info and taking the time... will really help me.
I have all components ( All delivery company drivers know me by first name, ha! ) except the M1 (next week I think), the Corsair PSU -SF600, and the other AIO, the Corsair H100iV1.
Necere (the M1 designer) posted this list that he is updating as new results are posted: Geforce GTX 1080 Compatibility List.
Another resource from the very first post: A user-contributed Google docs spreadsheet, covering parts and compatibility ( edits are public and affect everyone - be careful!)
thanks! Checked the spreadsheet already but hadn't seen Necere's post.
since this card is on the list: GIGABYTE - Graphics Card - NVIDIA - PCI Express Solution - GeForce® GTX 10 Series - GeForce® GTX 1080 Xtreme Gaming Premium Pack
I'll just go ahead and extrapolate that this card I was looking at would fit too: ::Palit Products - GeForce® GTX 1070 Super JetStream ::
The dimensions is slightly smaller. Palit doesn't seem to be popular over there, but the few reviews I've found of this seems positive
With the sexy windowed chassis' we have seen sprinkled throughout the thread, I wonder if Ncase might consider actually offering a windowed side panel option for the M1…!?!
And that said, how much of an overall cooling/performance hit might accompany the choice to go with a side window/bottom radiator (possibly supplemented with the rear exhaust-mounted 92mm radiator) set-up, versus the 'traditional' side panel mounted radiator set-up…?
I just LOVE the image of SO much water cooling packed into the M1, and all on display…!
…while playing WoW for 1 hour straight with settings maxed out!
But what type of playing…? Just bopping about, farming mats & rep & stuff; or full-on raiding…?
No problem. I just rebuilt my case last weekend so it's all somewhat fresh in my mind, Everyone's has different build preferences and components that may require a different build order. For example your SF600 has (so I've read) modular cables that are stiffer than my SX600-G, so that must be taken into consideration during the build process. With the M1 you need to plan your cable management ahead of time. I found using a couple of tie-wrap anchors really helped to organize my build, making it cleaner and easier to take apart in the future. I put one in the top rear panel corner above the I/O Shiled to hold a PWM fan splitter and a fan extension cable, the other on the side of my PS to hold some of the excess length of the power and data cables going to my front panel drives. As was stated a few posts above PLAN, PLAN, PLAN !
