DarkStryke
- Sep 19, 2001
Search isn't being very helpful. Any Canadians that have purchased in the last year or so mind sending me a PM?
Well.. she's all painted and put back together. Now.. WHAT SHOULD I NAME HER?
Scarlet Witch? Red Dwarf?
Would you guys recommend a Blower style cooler or an open air? I will be populating the two bottom slots of the case with two SP120's, would this give enough airflow to warrant getting the board partner GTX 1080's?
OC.net link is dead....I'm running Corsair LPX 3200s at their rated speed without any issues at all on my Asrock X99 ITX.
Ripjaw Vs work fine as do Corsair Dominators, neither of which are on the supported memory list
Narrow ILM is quite different to the stanard LGA2011-3 - you will need a separate adaptor. I don't think any AIO kits come bundled with one?
Theres a good summary of compatible coolers here:
http://www.overclock.net/t//lga-201...one-liquid-cooler-compatibility#post_25093300
I am in the same boat right now. Thinking of ordering a founders but earlier iata posted about the g1 gaming getting good tempo so I am still unsure. I'd rather get 100 off and get an open air but if a blower is indeed better I will just pay the extra.I haven't yet ordered my card for the v5 build but I have been leaning towards blower just to keep the hot air out of the case. That being said I would like to see some temps of the 3rd party cards to see if the extra heat dump is even that large considering we have very few blower style options.
Hey Guys,
Tried to do a search on the thread but hit too many results and figured I'd just ask.
Anyone know if the Ncase M1 v1 motherboard cut out fits most m.2 SSDs?
Thanks!
I bought a EVGA SC 1080 last week before I found out that the blower style card was preferred.
Do you guys think I should try to find someone to do a local trade for a reference card?
Or it would be fine if I just put the EVGA SC into the Ncase M1? As it stands right now I'm not interested in OC'ing my card.
i recommend returning it and getting the cheaper $609 EVGA Blower style 1080. I was running furmark and I hit the 81 degree throttling point at stock clocks and not only that but it dumped so much heat into the case that my cpu reached 80 degrees (it was maxing at 56 degrees during furmark when I was using a blower style r9 290). Avoid the open cooler for best performance, it'll be loud but the blower will perform much better.I bought a EVGA SC 1080 last week before I found out that the blower style card was preferred.
Throw it in there and let us know how the temps are! I am kind of waiting for the cheaper blower cards to come out but also thinking about picking up an open air cooler.I bought a EVGA SC 1080 last week before I found out that the blower style card was preferred.
Good job scoring a 1070, how are you liking it? I am waiting for some reference, non Founders Edition to come out. Great looking build are those EnSourced cables or did you do them yourself?
Looking really good. Could you talk a little bit about its performance in terms of noise?
Sexy build, is there a reason you put the fans exhausting thru the radiator instead of intaking thru the side panel?
That should be better for keeping the case cold, but combined with the blower video card will be a lot of negative air pressure. I hope he is not in a dusty environment.
It's great so far. I came from a gtx 670... so yeahh![]()
http://i.imgur.com/bJ1elR5.jpg
Seems to max at around 78 degrees with my fan profile at 100% GPU load. I have it set to 80% @ 70C and 100% @ 80C.
I tried overclocking a bit and got to +190MHz GPU offset before it started artifacting in the heaven benchmark.
Then at idle from 0-60C I keep it at 35C which is barely audible.
I mean.. any card at 80-100% fan speed will be noisy? It's really not too loud at idle.
Honestly I'm not sure.
What would be the proper way to set it up?
It's late. the cabling is a mess, but it's alive and I can confirm the EVGA 1080 ACX 3.0 SC fits.
I posted about it a few posts up. The Superclocked 1080 hits 81 degrees after 4-5 minutes in furmark and starts throttling. It also raised cpu temps by 26 degrees in the stress test compared to the stress test temps from my reference 290.Very cool, be interesting to see temps of the system in stress tests once you have all the panels back on. Congrats on the build.
Is this with the stock fan profile or have you adjusted it? Also do you have any 120 mm fans below the card or any exhaust? Thanks!I posted about it a few posts up. The Superclocked 1080 hits 81 degrees after 4-5 minutes in furmark and starts throttling. It also raised cpu temps by 26 degrees in the stress test compared to the stress test temps from my reference 290.
I haven't had time to mess with the fan profiles yet but I'm planning to do that tonight. I have two noctua industrials underneath it. Although one isn't hooked up because I don't have a second fan header, the splitter cable should've arrived yesterday so hopefully it'll be waiting for me when I get home. Once I hook up the second fan and tinker with the fan profiles I'll post how it went.Is this with the stock fan profile or have you adjusted it? Also do you have any 120 mm fans below the card or any exhaust? Thanks!
I am actually still in the process of building. I am going to use an AIO but am still leaning towards a blower card just to keep the heat out of the case. Thank you for your input though, it is helping me decide! Also if anyone is planning on using one of the newer Enermax Liqmax 2 AIOs the block seems to be fairly large. I just tried to install the 120mm version and the tubes coming out of the block were pushing on my ram pretty hard (Asus z170i pro gaming). You can change the orientation but having the tubes to the right seemed to be the best for hose flex. Just a heads up if anyone is planning on using one of these in the ncase.I haven't had time to mess with the fan profiles yet but I'm planning to do that tonight. I have two noctua industrials underneath it. Although one isn't hooked up because I don't have a second fan header, the splitter cable should've arrived yesterday so hopefully it'll be waiting for me when I get home. Once I hook up the second fan and tinker with the fan profiles I'll post how it went.
Unfortunately it doesn't change the fact that it raised my cpu temps by 26 degrees at load, that's quite an impressive amount of heat it's dumping in the case. I don't know how your Ncase is setup but if you have a 92mm tower cooler and a pair of 120mm fans mounted on your side bracket you should fair better than me when it comes to cpu temps.
Those would be your only choices. I'm going with ek's 100mm res + d5 revo pump combo hanging out the back.Well adjusting the fan curve helped get it down to 79 degrees max with no throttling. Still that leaves practically no room for overclocking.
Does anybody know of a good pump cpu waterblock combo. The apogee drive 2 has some serious leakage problems all across the Internet and I don't want a gaint pump/res combo hanging off the back of my case.
If you're going to be using a full cover block on the GPU you can fit a DDC pump + Aquacomputer Aquacover DDC top on the floor of the case. A few people have done builds with that combo.Does anybody know of a good pump cpu waterblock combo. The apogee drive 2 has some serious leakage problems all across the Internet and I don't want a gaint pump/res combo hanging off the back of my case.
I don't believe we'll be stocking individual side panels, unfortunately. I tried to make the case for them to w360, but he insists because we don't have the proper packaging for them and they end up being fairly expensive due to shipping that it doesn't make sense to stock them.im after a black left side panel so i can mod it with glass... when is stock expected?
Very nice, even your core temps and system sensors are pretty good.Thanks Bijiont! I've been running Heaven benchmark on loop, and GPU temp stabilized at 73c.
This is my airflow layout. Pardon the poor picture. x2 120mm Silencio fans on the bottom. Double Noctua Redux on NH-U9S and exhaust. This is with poor cabling so far, and no fan profiles.
[QUOTE="exzacklyright, post: 1042355207, member: 241111"
