Or guess I should ask, if I'm going to put a single 120mm case fan in, where should I put it?
We're not offering the black USB ports from the V5 for sale separately at this point, but possibly with the next production run we will. They should be compatible with versions all the way back to V1, as well.Pushing this question, because i really want those !
Yes, the chassis is riveted.Can someone tell me if the M1's cage is rivetted together? Or is it welded? Or is it held together with screws? I don't have one yet, but i'm thinking of ordering one and maybe anodizing the inner case but if it's riveted, then i'll have to drill it all out to disassemble before anodizing.
I'm in the opposite boat. Just waiting on a psu and a aio wc. But the case has all the rest waiting inside.Damn mine is still stuck in customs i want to build my new PC, only part im missng
So frustratet seeing all the build logs of the new v5
srsl hate my country is always the custom clearance which takes more time than the actual shipment
you really should insulate the pipes. I could see the vibration from the fan causing the pipes to wear into the back of the card.
By the way, what kind of cpu temps are you guys getting with the tf? Thank you.
Great temps!Well I've hit a max of 56 degrees on the 6700k putting it through stress tests. The GPU maxed out at 94 degrees before going into thermal throttling but it's a reference 290 so that's to be expected in any case.I've installed the Noctua industrial fans as intakes in the bottom, only one (the one above the gpu blower) is connected until I order a pwm splitter cable. Overall it looks like there's a lot of overclocking potential on air using the dark rock tf. So air cooling has plenty of potential in this case, if you have the money I'd go for a water loop as it'd be less work to install/fit together as long as you plan out the tubing correctly.
good call. even just a little e-tape.It's only rubbing on one of the screws for the heatsink, so not worried about that. I'll still put something in between when I open the case next anyways.
Yes, it's removable.Another quick questions. Is this front USB/Audio port thing removable? Or is it replaceable?
They're pretty normal.Here's mah new v5 build. Pretty standard stuff. I had a question about my temps though. Playing Witcher 3 on an ultrawide at 1080 I'm getting high 50s to low 60s on the CPU and the GPU sits pretty consistently at 70 degrees. Are these temps acceptable?
Imagine your bottom two fans with the hub and blades removed. They will act like ducts, allowing the GPU's own fans to draw air directly up from the bottom vents, without recycling any/as much of the GPU's own exhaust.Someone on the last page said adding ducts to the GPU would help with temps. Could someone explain this in more detail or tell me what page it's on? I don't get how the airflow is supposed to work.
Yes.hey thanks for the quick response. so the hot air would exhaust from the sides of the heat sink and then rise upward?
I assume you are cutting out two extra expansion card slots for the GPU, care to show me where you plan on doing that. I just wanna see the end result (even if its just a conceptual drawing).
The radiator is a Magicool LC-RADI240S, 276 x 120 x 45mm, copper fins, 14 fpiThat is a beefy looking radiator. Which one is it and what fans are you using?
Nice build, shame about the tap! What riser cable are you using?Here is how far I came with my GPU vertical case mod, if anyone is interested.
Now I am at the point where I have to mount the GPU. And to have something to mount it to, I got some angled metal plates, wich I cut to length and wanted to drill some holes to mount them. And here is what happened in the process.
Being frustrated right now.
Here's mah new v5 build. Pretty standard stuff. I had a question about my temps though. Playing Witcher 3 on an ultrawide at 1080 I'm getting high 50s to low 60s on the CPU and the GPU sits pretty consistently at 70 degrees. Are these temps acceptable? CPU is a 4590.
I think it's a little on the hot side so I ordered another 92mm for the CPU cooler and I plan on buying another NF-F12 for the GPU because one is an S12 which isn't really meant for heatsinks. Doubt that will make much of a difference but I'd feel better if the CPU stayed closer to 55.
I second this question, never seen that riser before.
Thanks, and love the build log!I just created a build log. WIP and by that I mean not only the build log but the project itself. You find the answer there
NCase M1 mod for vertigal GPU - build log
But I don't want to make people mad: Lian Li PW-PCI-E-1 Gen. 3.
It wouldn't work. They want to get money back on their investment. They are looking for things that everyone would buy (cleaning sponge or a super strong fix tape).NCase needs to go on SHARKTANK and get more funding so they can increase their production volume, get more exposure, drive down the price, and dominate the small form factor field.
The big issue really is that my side panel is popping out a bit where the h75 is mounted but it's weird because I don't really see why. I figured something was popping out but I don't really see it. Any advice on cabling?
