Which Ncase version do you have? I'll have to take a look at mine when I get home and see if it's actually too low or too high, I forget which direction it was off.
Since we are talking air coolers: I have my NH-C14 but I am waiting on my case to arrive and the Corsair PSU to be for sale.
I was planning to do something like this:
smaller fan on bottom
^ the alingement doesn't look to bad from the pics, but not sure if it's just the pics.
Can you not screw down the MB into the case? Or are ports blocked due to the misalignment ?
Well, when looking around I found this review:Going for the same kind of built.
with the evga gtx 980 ti hybrid fan on the bottom plus another one. both on intake from bottom.
but it seems like multiplying the fan is not always the good solution.
Bought a ncase v5 from the new batch for building a small gaming PC.
What mobo do you recommend?
Is there some to avoid/some to chose specially?
I'll probably use:
CPU 6700K
RAM 32GB DDR4
GPU GTX980TI
PSU SX500
SSD BX100
WC EK GPU+CPU+DCC+240mm+120mm rads
http://www.silentpcreview.com/article1138-page5.html
Since I will have an X99 build with possible a top mounted M.2 drive the lowered VRM and northbridge temps in that chart make me edge towards dual fan for my build
Just got my build done! This case is absolutely wonderful! You can tell that it was made to be as versatile as possible in so many potential configurations! It's just great design all around. Despite being small, it's not frustrating to work with getting at things through the open cage. Anyway pictures!
http://imgur.com/a/0ilzf
http://pcpartpicker.com/p/kL7pt6
- bhtooefr mentioned that the sx600-gs cables are too long. It is actually possible to route the flat cables behind the motherboard and it makes the cable length just perfect. I think I managed a pretty clean setup cabling-wise. Having only an M.2 SSD in the machine helped a lot.
- Getting the computer silent is really dependent on the fans and the fan settings. I had 2 Noctua low-noise-adapters and was able to lower the noise of the 3x 120mm NoiseBlocker fans tremendously. The idle noise is barely distinguishable in a room with an ambient noise level of around 40db (iphone db meter) or so.
- Temps on the i5-6500k at load running the Heaven benchmark and Prime 95 (4 threads) stabilizes around 65C
- Temps on the GTX980 with the Arctic Accelero Xtreme III heatsink & 2x 120mm fans running very low stabilize around 78-80C. I was able to run the fans a bit faster and GPU temps at load did stabilize around 65C.
Why did you use the Accelero Xtreme III heatsink & 2x 120mm and no Noctua 120 mm? are they quieter? more effective?
And why did you chose the Noctua NH-L12 37.8 CFM CPU Cooler and not the NHC-14?
did you find any advantage using this particular cpu cooler?
You should had a picture of the M.2 ssd. seeing your picture comfort me on using only a m.2 ssd. that a lot cleaner.
It looks nice. I don't think card flex is a big issue with cards without backplates. Are you running dual SSD because you upgraded from the OCZ to the Crucial and had nowhere else to use the OCZ?
In my experience, the MSI will benefit a lot from side exhausts and since your CPU doesn't need a ton of cooling, it might be an idea to do that and maybe do rear to front for the CPU.
Side fan would make sense, I was a little concerned about the cooler being non reference style and what that would mean for air flow. I'm not sure I understand your reasoning in back to front air flow. Wouldn't that just blow hot air into the case and PSU?
I could see why front to back would be better though. If the CPU cooler is bottom up the hot air rising from the GPU would run through the heatsink before leaving the case.
Hmm, using the Dark Rock TF is very interesting... Wonder if it will fit with the Asus Z170I Pro Gaming. It's not listed at all on the Google Sheet.
Does your motherboard have one of those padded I/O shields? I've noticed they do make it much tighter for the motherboard. Using just the three screws shouldn't pose a problem, though.1. I couldn't get my last motherboard screw in. Like literally it won't allign.. and the I/O shield is pushed as far in as possible. Should I just say Fuck It?
Those are the 2.5" drive stacking brackets. You can use those to stack two 9.5mm or 7mm drives together and mount them to any of the three 2.5" mounts. See this pic. Note that the mount behind the front panel only has enough room to stack two 7mm drives.2. What are these for? 4 120mm fan mounts?
It's more like angling it in, but yeah, it can be done with the motherboard installed.3. I can just slide my psu in right when it arrives? (Having already installed the mobo)
Would voltage control over the Noctua 140mm fan provide sufficient control (and would that mean affectively forcing my 120mm PWM fan to act as a 3 pin fan by virtue of using a fan header splitter? Perhaps I would need to use two PWM fans or two 3 pin fans if using a splitter) or am I best to go the whole hog and replace the 140mm top fan with a PWM fan so that the set up is entirely PWM?
Yes, voltage control will provide sufficient control. And yes, if you use a splitter and force voltage control on the mobo, your F12 will also act as a 3 pin fan.
There is absolutely no need to replace the top fan.
I'm using an F12 PWM and 3-pin GTs with voltage control on all of them.
Not sure why you're adding that fan on the bottom? Seems like it would provide no benefit and potentially only get in the way of the GPU.got a new hard drive and tried to fit in a 120mm on the bottom while installing the drive. Ended up fitting perfectly with right angle connectors on the drives and a little cable wiggling from the front panel connectors.
http://i.imgur.com/dCd9anLl.jpg
http://i.imgur.com/7J7BZBml.jpg
http://i.imgur.com/tuoniKXl.jpg
http://i.imgur.com/1Gx2Qw0l.jpg
I decided to go with the dark rock tf and the Asus z170i. The heatsink will fit if you a) use only dimm slot b for the ram or b) use a riser card to move the gpu to the bottom brackets. I went with option a because I wanted to complete my build but might buy a riser card so I can use the dual channel kit I bought.
The build is going to be a tight fit but the top fan will fit on the dark rock even with the fan bracket insalled. This combo however will not allow you to use the second spot for the intake fan or hdd bracket.
Hi, I'm new to this forum but have been following this thread since the beginning.
Well, the NH-C14 costs ~$80 here from retailers like Newegg or slightly less from Outlet PC: http://www.outletpc.com/al4988-noctua-nh-c14-cooler-intel-amd.htmlI have two RAM sticks and spending money on a riser card just further extends the cost for me, so I think I'll stick with the NH-C14.
You US guys don't know how lucky you are - the cheapest NH-C14 here is approx $80....
You might want to check your HDD temperatures. I had that congifuration before with HDD under a reference 980Ti, and it got way too hot with the GPU under load.
Even rear exhaust GPUs radiate a lot of heat from the shroud on all sides.
Hello everyone, recently I've been looking into selling my iMac and starting fresh with the NCASE but because everything is in USD I'm not exactly sure how much it would cost for me in the U.K., especially when I include possible customs charges etc.
I have a rough estimate in my head of around £170 to £200, but I would like something more 'concrete'. So would someone who's purchased the M1 from the U.K. be willing to share with me (Through this thread or a possible PM) how much it cost them please? (Sorry if this sort of question is inappropriate or posted in the wrong section of the forum, I'm a newbie here).
I ordered a v5 last month and the case including air shipping to the UK (direct from Taiwan) is £155 so far.
Once it's here you should receive a letter from ParcelForce stating the additional tax (VAT @20%) and import duty (I'm still waiting for this - my case has allegedly left Taiwan .
I'm expecting ~£40 in additional charges.
