Very long time lurker on the M1, but now I need to ask a question since I'm beginning to get my parts together.
Has anyone thought of a way to use two ALO coolers in the build? With the introduction of NZXT's Kraken G10, I've been trying to figure out a way to use a closed loop cooler on both the CPU and the GPU. Will the rads from the cooler be able to be mounted upwards on the M1's side bracket with the tubes coming out of the top/bottom? It would be nice to have a cooler with both the CPU and the GPU.
http://www.nzxt.com/product/detail/138-kraken-g10-gpu-bracket.html
You haven't lurked enough, then. That's where the Swiftech H220 comes in, since it's expandable, you can simply add the GPU with a normal waterblock.
And at best, you could add a 2nd 240mm ram in the bottom.
I would run into the same type of problems that people are having the the Asrock z77e M-ITX board with clearance with the dimm slots
Edit: lol I may just buy a new board
When I get mine, I'll let you know. I'm planning on attempting to run dual AIOs. As of right now, most probably with two Corsair H75's. Sure, it may be a tubing nightmare, but I say screw the naysayers and try it anyway. If it doesn't work, I'll just keep one and leave my CPU air cooled. Either way, I'll post pics and whatnot in this thread.
