slabhatnik
- Sep 19, 2013
davee- is your bequiet fan mounted outside or did you manage to get it into the psu enclosure?I guess any 80mm x 25mm might also work mounted to the outside of the PSU housing.
So it can be done with a fan other than the Noiseblocker NB-BlackSilentPro PC-P 80mm.... I was just wondering this last night and in fact looked at the bequiet fan you just referenced, curious if it would also work (as it is 25mm and the Noiseblocker is 15mm). What are the requirements other than 80mm for the fanswap in the ss sfx? I am confused as to whether or not it should be a PWM fan, what the rpms should be, and how you are running it at 9v....
Just found this picture... very happy, that the H220 will fit with no Problems (Ram, Sound...):
http://i.imgur.com/coDQvwkh.jpg
Anyone waiting for the Adamantium Res, seems like fronzenQ had an accident at the shop.
"Due to a laser fire that damaged a large portion of our shop, we will be closed until Monday 11/11/13.
If you have any outstanding orders we will be working to get them shipped out as soon as possible.
Thank you,
Alex
Alex Quaintance"
I guess it might be delayed for a bit![]()
Although barely spareing a few millimeters on the top. So you're mounting the heatpipes towards the top.
You do realize that Noctua advises against mounting the heatpipes upwards?
http://noctua.at/pdf/manuals/noctua_nh_l12_manual_en.pdf
If I were you, I'd check temperature, maybe you're fine, but mayhaps you would run into problems..![]()
Anyone in the US receive a case yet besides VIPs?
I think it's only fair that you us americans are last considering you paid less![]()
Not our fault your countries charge you for importing![]()
I meant the actual campaign. Intl pledgers had to pay $40 more![]()
Nothing here in NJ yet...
And that we don't have to pay customs and those sort of things.![]()
That's shitty. I'm glad to be American at times. Other times. . . not so much.
Check your pm.
wanna trade feets?
Does anyone know how thick the DEMCiflex filters are (with the ferrous tape)? It seems that the space between the left panel and the fan bracket is about 2mm.
I wouldn't advise to go for an 290 (or X), much less if you plan to overclock it. Why?
This is the total power consumption for the whole system, a system that is actually more power hungry than any we will put into a mITX system (Because there is no LGA2011 love for us ).
BUT, the thing to note with Volcanic Islands cards is that...
a) They all throttle with their stock heatsink, unless you run it really really loud.
b) The charts show no overclock.
So, once you remove that limiting factor, which is the temperature, via a decent cooler... the power consumption will increase. Even more so if you plan to overclock.
All in all, the 290s are far too power hungry to be deemed "good" for a 450W psu. If you are not into overclock... then, maybe, but still, the cards are far too loud for me to be any good at all in such a small enclosure.
To each his own, though.
290X overclocked (don't remember the numbers though) maxed out at 425W including AC/DC loss. Still nothing to worry about.
I'm not super knowledgeable about PSU's, but I believe 80+ Gold means the efficiency is at least ~90%.
This would mean your PSU possibly dies if you try overclocking the 290X. I wouldn't say this is 'nothing to worry about'.
So let's get the ball rolling:
This is what I'm using in the build:
● Ncase M1 - N° 0796
● Asrock Z87E-ITX
● Intel Core i5-4670K
● Noctua NH-L12
● 2x 8GB Crucial VLP 1600MHz
● AMD Radeon R9 290X (reference)
● Samsung 830 256GB SSD
● Silverstone ST45SF-G 450W SFX PSU
http://i.imgur.com/bFHQIqn.jpg[img]
So the orientation for the NH-L12 on the Z87E-ITX I [url=http://hardforum.com/showpost.php?p=1040271264&postcount=32]used for the CM Elite 130[/url] doesn't work, it sticks out at the top (see pic) and towards the I/O ports.
[img]http://i.imgur.com/twt2zjq.jpg[img]
So don't install this cooler on this motherboard like this, it won't fit.
[img]http://i.imgur.com/e4G5YLc.jpg[img]
But this orientation does !
[img]http://i.imgur.com/M6y55Cq.jpg[img]
[img]http://i.imgur.com/vqiOwo6.jpg[img]
AMD Radeon R9 290X fits, I routed the HD-AUDIO plug over the GPU to not bend it too sharply. You can zip-tie it at the bottom (top of the pic) on the side to secure and hide it.
[img]http://i.imgur.com/do1NwAk.jpg[img]
Here you see everything mounted and connected. I like the SSD being tucked away to the right.
[img]http://i.imgur.com/2gjHuKi.jpg
Where did the SSD go ? It just vanished.
http://i.imgur.com/WIqcjC0.jpg[img]
Top view, here you can see the CPU has about 55-60mm left. So enough for a slim radiator.
[img]http://i.imgur.com/93pVO2H.jpg[img]
Although the CPU backplate isn't fully accessible (an issue for later), the mSATA slot is.
[img]http://i.imgur.com/plRlanV.jpg[img]
Nothing but cables in the front. I put the T-shape SATA power connector just inside that slot so I don't have to stuff it somewhere else. Zip-tie to keep cables from moving about.
[img]http://i.imgur.com/9Za6hXa.png[img]
Top view showing the clearances. I didn't have any cables acting strange.
The assembled computer is quiet, CPU is a little less cool than in the Elite 130 but it also had an extra fan. I might change the fan profile to compensate, I'll need tot test.
All in all I am damn impressed with the work done by Necere and Wahaha360 in designing a brilliant case and delivering it to my door with the best trans-continental shipping experience ever. You guys deserve medals for being pinnacles in the community. Respect and love for the both of you ![/QUOTE]
That looks really, really good. I think the Noctua NH-L12 is the ideal air cooler for this build. I'm using the SFX PSU, LVP RAM, and blower GPU. I've got the Asus Impact Motherboard so hopefully there will be a little bit more room around the edges for the cooler.
And also, no case fans? This is going to be awesome!
Hoping to find a 400GB+ M.2 NGFF SSD for the Impact and not have any other internal drives. I've got a 10TB media server for more space if necessary. For now, I may just put a traditional SSD in there.
The only M.2 drives I can find are 80 and 128gb. Let me know if you find any larger for sale.Hoping to find a 400GB+ M.2 NGFF SSD for the Impact and not have any other internal drives. I've got a 10TB media server for more space if necessary. For now, I may just put a traditional SSD in there.
I have tried to find every single possible picture of this one, and my SUSPICION is that this one will also allow you to install the side fan, Just maybe. (i.e. less than 115mm tall)
Would Love to have one of those. In my Asrock Z87eITX board, the Noctua U9B in a vertical orientation fits with 1mm to spare between it and the ram sticks. (permitting unlimited ram height)
My hopes with the D type is that it fits both ways, both up and sideways, depending on whether theres a limitation on the efficiency of the cooler in the horizontal orientation (airflow wise)
What I am more worried about though, is if it ever comes to market.... This would be something I would seriously consider instead of my U9B
looks like a mini mini D14... D9? I don't know how it would perform vs the C12/C14 coolers
they're saying Q1 2014 on their website, worth the wait? I'm eyeing the C12 and still maintaining compatibility with the side bracket, but if this new prototype also fits then I must say I prefer the tower style cooler
Hoping the d9 gives me the tower design benefits of the vertical airflow pathway as well as the benefit of a side fan for helping to introduce cool air for the cooler in higher load situations which the u9b could benefit from at this stage. Essentially after a tower with a low enough profile to fit a side fan.
I suspect a side fan won't fit with the d9 but you can always use the back fan as intake and let positive pressure do its work for exhaust. Assuming that the back fan fits...
I had indeed realised this, but the caring factor was almost zeroYou do realize that Noctua advises against mounting the heatpipes upwards?
While the Asrock Z87E-ITX isn't centered, it's still not as bad as most Z77's are and some Z87's still are. Current Z87 motherboards:that could be the reason for higher temps... But nice to see another build going forward!!
In Addtition the very high socket position of the Z87E is not good either...
I wouldn't call the NH-L12 ideal since it's lack in cooling capacity (only an issue with overclocking), but it does allow to use the CPU heatsink on air and a radiator on the side to liquid-cool the GPU, which I'm leaning towards.That looks really, really good. I think the Noctua NH-L12 is the ideal air cooler for this build. I'm using the SFX PSU, LVP RAM, and blower GPU. I've got the Asus Impact Motherboard so hopefully there will be a little bit more room around the edges for the cooler.
