Im thinking of using my 1 TB drive as a media drive for my setup. Currently I have:
1) Deskop - eSATA, 1xGigaLAN
2) Laptop - USB, 1x 100Mbps LAN
3) 100Mbps Wireless Router with 4 port switch
I dont switch on my Desktop 24/7 so I plan to get a drive enclosure for my hard disk. I will be storing all my BT and media files in that 1TB drive. I have done some research and here are what I found out.
1) USB/eSATA - Fast data transfer rate, 30MB/s for USB2.0 and almost max for eSATA.
2) NAS - Bit Torrent feature looks tempting because I plan to use it 24/7 for BT. But I heard the built-in client is inefficient and will be slower and harder to manage than normal Windows BT client. Is it true? Since I'm using 100Mbps switch, transfer rate between my PC and NAS will be painfully slow, max around 10MB/s. Some NAS enclosures comes with print server function which enables me to share my USB printer with both my PC and laptop.
I really dont know whether it is worth to get NAS which is more expensive then normal USB/eSATA enclosure and slower. Please give your suggestions. Thank you.
