NAS behind 10/2Mbit ADSL modem
almalino
I plan to buy Synology 214play to store all my pictures and video at home network and access it when travelling via 10/2mbit ADSL modem I have at home.
What kind of performance in picture viewing, audio video playing should I expect via this relatively slow connection?
I think I can back up stuff from the phone back to NAS pretty fast over 10Mbit. What about viewing the stuff over 2mbit. Is it painful and too slow?
All depends on the bitrate of what you're trying to play back. If you use something like Plex, and just tell it to stream at a lower bitrate, you won't have anywhere near as many problems as you will if you try to stream a 1080P media file
Yeah, 1020P over 2MB is defenetelly not an option. But I guess it is still usable with lover bitrates but not too low? :)
Any video at < 2 mbps is going to be painful. Audio should work perfectly fine though.
Plex is the answer to make this a non-issue. I host a Plex server at my bro's house and just tune it down as-needed. Quality is just fine - he's on Comcast consumer cable.
Nah, with a modern codec, 1.5-2Mbps is not too bad, even at 720p and sometimes 1080p. 2Mbps would be about 1.3GB for a 1.5 hour video which with a modern codec like H.264 is not bad for HD. It won't be up to the quality of a good Blu-ray but it could beat Netflix quality by a LOT if done right.
Thank you for the optimistic view on the matter :) It sounds promising. I guess I will not regret the buy :)
2mbps for 1080p is a bit of a stretch IMO and you'd have to butcher audio to get there.
720p with decent video AND audio is definitely doable though. And audio-only will be no problem at all, even FLAC.
Netflix is ~500-600KBps so it won't touch netflix HD but it would crush hulu. Hulu on high is a mere ~125KBps.
1080p is not doable on 2Mbit but 720p can look pretty good at 1-1.5Mbit in my experience.
I use Plex, but I modified it's encoder to use up all 8 threads on my Xeon CPU to get a really high quality x264 encode out low bandwidth. The default Plex encoder is not tuned for quality but for speed and low CPU usage.
:eek: Oh do share will you? How did you do that.
I have some extra Xeon cores kicking around, and would love to use them for that purpose.
The downside of using Plex or similar for this is that you do indeed lose a lot of quality per bit when you have to be constrained by an encoder that must use very little CPU.
Still... the convenience is probably worth it to most people. Being able to have any bitrate media on your disks and just have it reencoded on the fly to work streaming from your internet connection.
Well, plex passes ffmpeg encoder parameters into the "Plex New Transcoder" binary which does the live encoding and streaming which the player listens to.
I simply renamed the "Plex New Transcoder" binary to just "Transcoder" (something different) and then created a simple shell script and named it "Plex New Transcoder". So what happens is the encoder parameters that were supposed to go to the real "Plex New Transcoder", instead go to my shell script. My shell script then modifies the parameters to my liking (higher quality settings) and then simply passes those modified parameters into the "Transcoder" like they were supposed to go to which is the actual "Plex New Transcoder" binary.
Here is my shell script that intercepts and modified the parameters.
Essentially what I have done is:
1. Change the default "Plex 720kbit option" to 1mbit.
2. Change the x264 preset from "veryfast" to "slow" (this has the most impact on quality)
3. Change the CRF value form a variable one to 18
4. Change the output resolution of the default "Plex 2Mbit option" from 1024 width to 1280 width (720p)
5. Change the output resolution of the default "Plex 1.5Mbit option" from 720 width to 1280 width (720p)
5. Change the output resolution of the default "Plex 720kbit option" from 576 width to 852 width (slightly better than 480p)
Code:
#!/bin/bash
pkill Transcoder
params=( "$@" )
for ((i=0; i<${#params[@]}; i++));
do
    pkill Transcoder
    if [[ ${params[$i]} = 720k ]]
        then params[$i]="1000k"
    fi
    if [[ ${params[$i]} = 1440k ]]
        then params[$i]="2000k"
    fi
    if [[ ${params[$i]} = "veryfast" ]]
        then params[$i]="slow"
    fi
    if [[ ${params[$i]} = "-crf" ]]
        then params[$i + 1]="18"
    fi
    if [[ ${params[$i]} = *1024* ]]
        then params[$i]="[0:0]scale=1280:trunc(ow/a/2)*2:force_original_aspect_ratio=decrease[n0];[n0]copy[out]"
    fi
    if [[ ${params[$i]} = *720* ]]
    fi
    if [[ ${params[$i]} = *576* ]]
        then params[$i]="[0:0]scale=852:trunc(ow/a/2)*2:force_original_aspect_ratio=decrease[n0];[n0]copy[out]"
    fi
    if [[ ${params[$i]} = *568* ]]
    fi
done
pkill Transcoder
/usr/lib/plexmediaserver/Resources/Transcoder "${params[@]}"
pkill Transcoder
Maybe there is a better way to do all this, but meh this works great for me.
Super elegant. I like it. Thanks.
Uhmm, I am running Plex server on a Windows box, will this work? Sorry, too tired to think for myself ;-)
That script wouldn't work natively in Windows, though it would probably work if you installed Cygwin with bash. Otherwise it'd need to be converted to Windows batch format (which might be a bit more complex - bash scripting is a LOT more capable than batch).
I don't know about Plex but all the reencoding programs I've used have let me set at least some of the settings myself. If Plex doesn't, that's dumb on their part.
A powershell script would be better than a batch I think :p Don't ask me to write it though, my pshell skills are way too limited.
I tried finding a place to set the transcoder settings but I never ended up finding any place that I could modify them.
I think that there must be a place though and I'd like to switch my method over to that.
In the Plex changelog I saw this:
Add a (hidden) preference to specify x264 options which override all others
https://forums.plex.tv/index.php/topic/62832-plex-media-server/?p=610519
But it's hidden! Where is it? I have not been able to find it.
What about the "Make my CPU Hurt" option under Transcoder?
Well, then I'm going to move Plex to a Linux box/VM. Thanks a bunch.
