MythTV Backend CPU Requirement?
T. Whatley
I recently purchased a z77 + i5 3570k combo that'll be going in my main system currently running an amd phenom ii 945 and ddr3.
I also currently have an amd athlon x2 3600+ and 2 gigs of of ddr2 powering a fedora 15 box. I was wondering, is this 3600+ enough to power a mythtv backend setup? I obviously plan on being able to live stream mythtv to a total 2 or 3 sets, in hd. Although, since I'm single, there will really only be 1 concurrent stream but there could possibly be 2 recordings happening at the time of the 1 live stream.
Side note: I currently stream 1080p mkv's perfectly fine (via wd tv live plus + nfs) from this f15 box, if that factors into the equation at all.
If not, I was thinking of dropping my phenom ii setup into the f15 box (which I would think should be enough) but would lead to more expenses on my end since I'd need to get a vid card and some more ddr3 to drop in. I'd like to avoid that and sell off the phenom ii setup for a little cash.
That should be way more than enough, if it's anything like it used to be a couple of years ago.
Try it and see.
Yes that x2 is more than enough. As long as you've got an Nvidia video card you will be fine. I would probably get a little bit more memory though. Aside from that you are good to go.
what would the video card have to do with a backend only setup?
i understand nvidia is the way to go for frontends... but backends?
Great... was worried for a second that I really didn't grasp something just when I thought I was beginning to grasp something.
