Lets start off with specs:
Thermaltake Armor (the black heavy model)
Athlon X2 6000+
Two gigs of OCZ Ram
Coolermaster Extreme Power Duo 600w power supply
PNY 8800GTS 640MB
Right, anyway, I keep having these shut downs, which tend to be 12-24 hours apart. I have a few theories for this, since I have ruled out it's my CPU or video card overheating (I've ran prime95 and superpi for about an hour.) Basically what happens is it just shuts down, no blue screen, no real warnings or reason for it. When it shuts down the power light blinks and I can't just turn it back on, so I have to power cycle the power supply then turn it back on.
Basically theory one is that the motherboard's shorting where it sustained an injury from a rogue screw driver. What happened basically, I was getting frustraited while prying off the old cpu cooler for my Athlon 3800+ and decided to use a screwdriver to get it off. Well, it ended up slipping and injuring about three printed wires that look like they're related to the cpu.
And theory two is the power supply is slowly overheating due to its design and the case's position for the powersupply. There's only one fan on the power supply and it's on the bottom (one big 120mm). And it's almost completely blocked by the full hard drive cage. The power supply auto controls the fan speed and it sounds like it's running max speed constantly. This seems the most possible and I'll probably end up flipping the power supply so it sucks air from the other side (there's actually more room over there
EDIT:
Here's the low-down on the current situation, and it's gotten a lot weirder. If I reinstall the nvidia drivers in safe mode I can game once I reboot into a normal windows session. But, I play Simcity 4 a lot and if I press "Don't save and go to region" in the options, it'll shut down the machine and break the nvidia drivers again (that's the weirdest part) to the point where I can't do any gpu intensive things (and I have to repeat the process again). I don't know if this is the only program which can break the drivers.
It literally works every time, all I have to do is just press "Don't Save and go to region" and the whole machine just shuts down, no errors, no BSODs. This wasn't like this yesterday and I haven't done anything to this machine since then.
Athlon X2 6000+
Two gigs of OCZ Ram
PNY 8800GTS 640MB
EDIT:
