I just had a hardware memory error on my system - XP SP2 - installed for about 2 yrs.
Of course - the mem error caused a lot of filesys damage. Once i replaced the mremory - all is good - except it won't boot XP anymore.
So I did a "upgrade" reinstall of SP2 It gets to the first reboot in the install - and says
" Error Message: Setup Cannot Set the Required Windows XP Configuration "- F3 to quit !!! Rats I checked the partition with a boot disk, and all seems ok. So close !!!
So then I tried a "clean" install into a new DIR on the same partition I put it into \WINDOWS2 Ran fine - installed completely.
The MS knowledge base says that the error means my hardware is not compatible or something.
Need some help to get the original Windows install back. I can see all of the original C: dirve - all seems to work fine.
