Hi all,
Here is my rig:
DS3 rev 2.0 (F9)
E6600
g.skill 2GB of RAM (4-4-4-12)
7900GS
Antec NeoHE 500W
Using Vista
Yesterday i decided to update the bios using BIOS flash utility from Windows. So, i updated to F10 and then it started.. The system was unstable at default settings, so i flashed back to F9, but it didn't help. I can't OC at all. When i try to change any settings, the system shut downs and then after a couple secs turns on at default MB tweaker settings. I wanted to clear CMOS, but i couldn't find a jumper on the board, so i took out the battery and put it back. No luck here too. I ran out of ideas, so your help is needed here
Here is my rig:
DS3 rev 2.0 (F9)
E6600
7900GS
Antec NeoHE 500W
Using Vista
