My SATA Drive Is Back!
Rx_Matador
so my sata drive is workign again after a little help from seatools. As awesome as that is that's not the reason why i'm here. Since my SATA drive was MIA i had to use an old IDE drive i had as my C: drive. I was wondering if there is a way to Switch all that info and the drive position to the SATA drive, without losing anything pretty much an entire drive copy.
So after doing my own research i tried using UBCD and none of the drive copying prgrams worked for me they all either only read my IDE drive or they just froze upon launch. So can anyone help me out?
I've used DriveImage XML before, but I prefer Drive Snapshot. You can run it from a BartPE CD. You should be able to get it working simply by adding your SATA controller's drivers to the CD builder.
