My Rocksmith Rig!
Discussion in 'Case Mod Gallery' started by P4B, Nov 24, 2012.
  1. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Hi [H] and everyone.​
    I have a new idea im working on now.
    I'm sure most have heard of Rocksmith by now. I use to play the guitar along time ago and got this game. Its kinda fun and im getting better at playing again. So i thought lets bring them closer together.I have been running the game on my i7 rig and a new Fender amp with a A/B-Y switch to get sound to both with great results. But with all the new wires over my room i thought it was time for a new build!
    I though i would reupholster this old Marshall Lead 12 mini stack i have had in storage for over 15 years because my pit bull took out her frustrations on my speaker when i was at work. I did just start playing back then, and I'm sure i was annoying enough to warrant such a review. ​
    The case is going to look like a Marshall MG lead 12 Amp piece. I'm going to make a replica box to add a ITX mobo M4A88T- Deluxe with a HD6670 gpu into it for my RockSmith game.
    With a Marshall wallpaper to make it look like it belongs in the set when not playing the game.
    I just got started on this and don't have much going yet except order receipts. So i have been mapping out my plans and getting my part list filled.​
    Found this for my display! 12.1" Digital TFT AUO B121EW03 LCD Screen Panel+DVI Controller Board 1280x800
    Heres a few pics for a better idea of what the final build should look like.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. Segovax
    Segovax n00b
    53
    Sep 4, 2011
  3. Jorona
    Jorona 2[H]4U
    3,380
    Nov 6, 2011
    I'd be pretty leary of putting a PC that close to a large unsheilded speaker and amp.
    Should be epic though if it works.
  4. jojo69
    jojo69 [H]ardForum Junkie
    10,424
    Sep 13, 2009
  5. thekinslayer
    thekinslayer n00b
    54
    Sep 8, 2012
  6. Hanniblex
    Hanniblex n00b
    54
    Aug 12, 2012
    I am really curious to see how this will turn out. subscribed! :)
  7. Grss429
    Grss429 [H]Lite
    78
    Aug 19, 2009
  8. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Still waiting on a few things. My A.D.D. kicked in a little. and im going to make a matching pair of speakers to go with this. So far i have stripped a Lain Li case for parts and got the tolex fixed on my amp. Instead of building a copy box i was lucky to find someone split up a set and i got the one i needed. Having a bud move the feet cup holes on top for free and still waiting. soon as i get it back ill start on setting the mounting plates. i have still have to choose what im going to wrap the screen with.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  9. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Mighty upset today! I trashed my front grill with a dremel. I'll have to use tin snips or hacksaw next try. Then i was also trying out the new screen i ordered. Did not power up. hope i can find a replacement.
    Here you can see my first try. It worked but its not clean enough for me so i reordered the sheet.
    Going to try to find a replacement screen set up. And wait for reply about the dod.
    [​IMG]
  10. Jake1003
    Jake1003 [H]Lite
    68
    Dec 24, 2011
    Keep us posted.. hope evrything goes well woith your mod!
  11. evilvicious
    evilvicious n00b
    58
    Jun 15, 2010
    keep us up to date , looking foward to seeing how this mod turns out , thanks.
  12. wra18th
    wra18th [H]ardness Supreme
    7,832
    Nov 11, 2009
  13. jojo69
    10,424
    Sep 13, 2009
    keep your head up
    setbacks have a tendency to really kick me in the balls motivation wise
    I am trying to learn to work on through them and not get discouraged
  14. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    So i have most parts in the case and believe everything will fit, but my old 5870 will not fit. No problem, its not going to be a full time gamer machine. This is just a for fun build using 1-2 year old parts and a few new items.
    I took all the brackets, plates, screen, and matched it all in white paint.
    [​IMG]
    After a few more coats of paint this will look great. Trying to get a clean look,and white matches the black/white style of the cab.
    [​IMG]
    While waiting on paint to dry i started converting my new and used mini amps i got on ebay for cheap into my desktop speakers.
    [​IMG]
    [​IMG]
    I have more photos but seem to hit a daily limit at photobucket. More to come this weekend.Front grill screen build attempt #2. I have a nice sheet bender now. And if that go's good then i have usb plugs and a on/off switch to to cut out. If this doesn't work i have a plain sheet of metal to use.
  15. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    I just removed the amp speakers and cut some of the battery compartment away. i used a 3-pc speaker set from Creative. I was going to get a Marshall box for the bass box but thought that was a little to much. Had to make some brackets for the speakers out of a CD case and cut a hole for the wire.Used a hot iron to remove the wires so not to lose any length. They work great. And maybe sound a lil better and louder.
  16. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Almost ready to put it all together.just missing a power supply for the screen.
    [​IMG]
    [​IMG]
  17. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    The Marshall Lead 12 part is done. Now complete focus on the cpu.
    [​IMG]
    link is gone
  18. wra18th
    7,832
    Nov 11, 2009
  19. Etherea1
    Etherea1 Limp Gawd
    268
    Nov 14, 2007
    That's a really cool idea, well done!
  20. jojo69
    10,424
    Sep 13, 2009
    very nice fit and finish
    well done sir
  21. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Having a problem with a vandal switch i got for the on/off switch. I know nothing about wiring a switch. I thought it would be easy. 4 wires what could go wrong.
    [​IMG]
    It has the + - and "no" "nc" and "c". now thats 5 tabs and i have 4 wires. my best guess is to run jumpers from c to nc and c to no with two of my wires going to + and two going to -
    but i dont know and dont want to fry the switch or cut the ends off yet to solder. any help or links would be appreciated Thanks
    As you can see i need to get the wiring done before i put the mobo back in. And then it should turn on.
    [​IMG]
  22. wra18th
    7,832
    Nov 11, 2009
    For the pc power side you want C and NO as normal power switches are monetary. If you connect C and NC your pc will shutdown after 4 sec. The + and - is for powering the light in the switch. Tap off one of the Molex connection for the + and -. Use the red and black wires. The yellow wire is +12. Don't use that one.
  23. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Thanks!! I tried it. Seems to turn on but not off without holding for the hard shutdown. Should be ok since you can just shut down from within the os.
  24. wra18th
    7,832
    Nov 11, 2009
    Holding it for shutdown is normal. You can configure the BIOS to do a normal shutdown with the button.
  25. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Past the test. Now to cut some wires.
    [​IMG]
  26. jojo69
    10,424
    Sep 13, 2009
    no=normally open
    nc=normally closed
    +and- are for the led
  27. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Not done yet but real close . Got it running atleast.
    [​IMG]
  28. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
  29. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
  30. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Here are some pics using the ASUS overclocker program. I'll get into the bios later for more tweaking. Anyways i got a nice boost.
    [​IMG]
    [​IMG]
  31. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Old and old new stock
    ASUS M4A88T-I Deluxe itx
    AMD Phenom II X4 925
    Cooler Master low profile heatsink,, Just switched out with a H70 old model with 2 extra fans on it
    Sunbeam Molex to 6 3pin blue LEDS
    Crucial 8GB (2 x 4GB)
    HD6670 1 GB
    WD 320GB
    FSP Group 400W ,, switched out for a Cooler Master 460W
    NEW STUFF
    2 6 LED each lights Red
    Custom Marshall Lead 12 cab/case
    Custom Marshall ms-2 speaker case's on a Creative speaker 3-pc set
    Vandal Switch
    ModRight ModMesh
    The Lead 12 got new TOLEX ,piping,corner caps, gold rivets,
    2 FrozenCPU RingPuk 10 LED. and wiring for the lights.
    4 caster wheels
  32. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    For the 12.1 laptop display.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    case is closed
    I still want to add a case fan,two more LED's, And some exterior cable management since i have 6 power cables on this beast.
  33. Kaos
    Kaos [H]ard|Gawd
    1,328
    Oct 14, 2003
    Is the "keyborad" used to control the monitor's functions?
  34. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    oops. forgot that the 12.1 display on this has the lil keyboard. That is on the front of all displays. That is your on/off for the display with the menu and other options that come with all displays. I have a KIT for the display that the display keyboard came unattached. This is listed above, but not all the parts that came with it. Someone on Ebay sells the kits or the parts that make up the kits. The kits are made to take a old/new laptop display and use it in any form of cpu combination.
    You can also see it hanging off the display a few pics up with the red LED where the back of the case is open.
    I used the paper to protect the "keyborad" from this sheet steal i used for mounting it.
    link gone
  35. ValeTudo
    ValeTudo Limp Gawd
    482
    Jan 29, 2010
    That is really cool and fun stuff!!! Once I find my new house, hoping to rig things up in a fun way like this, cheers!
  36. Kaos
    Kaos [H]ard|Gawd
    1,328
    Oct 14, 2003
    Thanks for the info!
    I'm just getting back into playing and considering rocksmith to help me build up my timing and chord transitions again. This build is really cool!
  37. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
  38. wra18th
    7,832
    Nov 11, 2009
  39. Allisons Dad
    Allisons Dad Limp Gawd
    192
    Jul 30, 2012
    Just picked this game up, it's a blast.
  40. P4B
    P4B Limp Gawd
    336
    Apr 28, 2012
    Get the extra game called Scale Runner opened up. That game is nice.
