my psu finaly hit its limit :(
Digital Viper-X-
my old trusty enermax liberty 500 is starting to crack! ( I think anyway)
just upgraded vcard, and had to drop my oc a bit to keep it stable :p currently I have a
Q6600 @ 3ghz 1.22v
8GB @ 800 2.1v
Maximus Formula SE
4870 @ stock
5 SATA 2 HDs(4x 7200.11 500gb, 1x 7200.11 1tb)
Auzentec XFI
lg dvdrw sata
anddd antec 1200(5 led 120mm, 1 240mm?(or 200mm)) and 1 120mm on the cpu.
I used the psu calculator at 80% load I should need about 460w
so time for a new psu :( This brave enermax liberty has served me for many moons. (3-4years?) I got it close to when it came out not even sure how long ago it was :D I've had this ever since my enermax 465
whats hot in the psu world these days.
I just got the Corsair 750TX. Damn, it's a nice piece of hardware for the price! And there's a $20 rebate on top of it all.
See how many other PSUs have 4x 8pin PCIe hookups at that price.
well I picked up the silverstone, it looks decent, at first the pc wouldn't post, after messing around with it it posted fine. seems to be ok now =)
I've only had good experiences with Silverstone. Hopefully yours will be the same. Good luck. :D
thx =) I've clocked the cpu back up to 3.2ghz, and o'ced the vcard a bit, seems to work well :D I can't provide a proper review, but it's handling what my aging enermax 500w was starting to fail at , so thats not so bad =p
Power supplies either work or don't. There is no middle ground. Only upgrade when stability is an issue and you've narrowed it down to the PS. I HATE IT when newbs say to upgrade a power supply for better fps and speed. Such horseshit.
Glad you got your system back Digital.
I've seen several of them explode lol... (actually, two just burned... one did explode :p)
Silverstone is a no go for me...
I believe that Corsair is the way to go price/performance-wise at this moment.
