Argh! I have 2 leaks now.
First Leak: The top (outlet) barb is leaking around the threads, probably going to epoxy both barbs on it permanently for peace of mind. Right now it is NOT leaking, I tightened it up with some pliers (it wasn't so tight before).
Second Leak: The removable piece on the inlet of the pump leaks around the o-ring. This is one I don't want to epoxy if I don't have to, but I need some solution to keep it from leaking. Any ideas?
As a side note, the way everything is setup ATM it will eventually bleed off all the air. I had to unplug it once
