My Planned Build(Thoughts?)
Ryboodle
1) Determine what the computer is going to be used for.
Gaming
Recording Games
Streaming
Video Editing
Some CAD programs like 3DS Max, Maya, and mudbox
2) Not a set budget but around 500 for everything
3) USA, VA, Richmond
4) MOBO, RAM, Case, HDD, SSD, CPU
Sapphire HD 6870
OCZ MODXSTREAM Pro 600W PSU
Monitor 1920x1080 HP 2509m
Keyboard Logitech K120
Default Mouse
6) Will you be overclocking? Yes
7) What is the max resolution of your monitor? What size is it? 1920x1080 HP 2509m
8) When do you plan on building/buying the PC? buying within the month as there are some good deals rightnow
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.well what i have now has pretty much all that i need
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? yea i am using an old copy of xp and will purchase win8 upgrade for like 40 dollars
This is what i have picked out right now
Case: Sentey Arvina Extreme Division Tower Case(red)
Power Supply (PSU) OCZ MODXSTREAM PRO 600W PSU
Case Fan(s): ones that come with
Motherboard: ASRock 990FX Extreme4
Processor (CPU): AMD FX-6100 Zambezi 3.3GHz
CPU Cooler/Heatsink with Fan (HSF) : one that comes with proc
Memory (RAM) G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1066
Hard Drive (HDD): Seagate Barracuda ST31000524AS 1TB 7200 RPM
Optical (Disc) Drive (CD/DVD/HD-DVD/BR): none ATM just going to borrow one from old computer when necessary
Video/Graphics Card (GPU) Sapphire HD 6870
Sound Card: onboard for now
SSD: OCZ Vertex 4 VTX4-25SAT3-64G 2.5" 64GB
OPERATING SYSTEM (OS) - Probably take an old xp key and get the cheap windows 8 Upgrade
WATER COOLING - I Hope to in the future it would be nice if you could point me in the right direction but no plans ATM
PERIPHERALS/OTHER ACCESSORIES:
Mouse Was an MX518 till it broke i am using an old default mouse came with previous computer but will probs get g400
Speakers logitech G930 headset
Get rid of all the OCZ stuff in your build.
What do you need IDE for?
If you plan on OCing your going to need to get a non stock heatsink.
For the PSU look at Corsair or Antec.
For a cheap SSD get anything but OCZ.
+1. 256gb M4/830/840 SSd would work. Antec/Corsair/Seasonic.
CM 212+ for your cpu, 2 x 4gb 1600 memory, not sure what that case is.
IDE?! :confused:
the ide is for my old floppy disks and maybe some old cd drives
and i already have the PSU that is the thing i am transfering along with my 6870
and the ocz i picked has some pretty good reviews and the most random read write speed for that pricepoint
oh yea and i only plan to clock it up to the spped of a fx- 6200 so shouldnt stock cooler be enough from what i know the cooler is the same between the two could be wrong though
EDIT i will update actual product numbers for keyboard and monitor and stuff
Just so that we can have an easier format to understand, please reanswer the questions in the stickied "ANSWER THESE QUESTIONS FIRST!" so that we can help you better.
yea sorry i just went to wrong sticky went to first one instead of second one all better now
Any chance you can wait another month? AMD's new "FX "Vishera" CPUs will be out then and might be a better choice for you if you really want to stick with that "red" theme you have going on now.
As for the case, IMO, that case is a bit too pricey considering that it lacks USB 3.0. Some cases around the $50 price point have USB 3.0 so it's a bit of poor value to see a $100 case with no USB 3.0.
As for the SSD, considering OCZ's shady history, I honestly would not recommend that OCZ SSD. I recommend the Crucial m4 or Samsung 830 series SSD.
Thanks For Telling me about the new AMD chips I had no idea pile driver was coming out so soon(it certainly pushes back my date for purchase thanks for letting me know)! Do you think that the 6300 will be totally different architecture and not just an PRE-OCED 6100 like the 6200?
The Extreme edition case is one of the cheaper full ATX cases that I saw on Newegg and it has devoted fans for GPU and Hard drives and there is no denying it looks epic but I am open to a $50 full atx case with similar features to the extreme edition
Also I almost exclusively Shop Newegg for there prodigious Customer service(except for water cooling and stuff as they don't really have a lot where that is concerned)
I will update the thread with suggestions soon
Couple things:
1) The FX-6300 is based on the Piledriver archticture, a refinement of the Bulldozer architecture. So not a totally different architecture
2) The FX-6200 is higher clocked than the FX-6100. It is not a "pre-OC'd" (did you mean post?) 6100
Oh I can deny it looks epic: It only has 80mm side fans which are either gonna be too loud or not push enough air and it lacks USB 3.0. I recommend any of these cases instead:
$80 - Corsair Carbide Series 300R ATX Case
$90 - Corsair Carbide Series 400R ATX Case
$100 - Antec 1100 ATX Case
$105 - Fractal Design Define R4 with Window Arctic White ATX Case
$105 - Fractal Design Define R4 with Window Titanium Grey ATX Case
$110 - Fractal Design Define R4 with Window Black Pearl ATX Case
$110 - Fractal Design Define R4 Arctic White ATX Case
$110 - Fractal Design Define R4 Titanium Grey ATX Case
$110 - Fractal Design Define R4 Black Pearl ATX Case
$119 - Corsair Carbide Series 500R ATX Case
$120 - NZXT Phantom PHAN-001BK Black ATX Case
$120 - NZXT Phantom PHAN-002OR Black Finish w/Green Trim Full Tower ATX Case
$120 - NZXT Phantom PHAN-002OR White Finish w/Red Trim Full Tower ATX Case
$130 - NZXT Phantom PHAN-001WT White ATX Case
$140 - Antec P280 ATX Case
$140 - Corsair Obsidian Series 550D ATX Case
$140 - Corsair Vengeance Series C70 Arctic White ATX Case
$140 - Corsair Vengeance Series C70 Gunmetal Black ATX Case
$144 - Silverstone RV03B-WA ATX case
$160 - Silverstone TJ04B-EW ATX Case
$160 - Thermaltake VN300M1W2N Chase MK-1 ATX Case
$160 - Corsair Graphite Series 600TM ATX Case
$162 - Corsair Obsidian Series 650D ATX Case
$178 - Silverstone RV02B-EW-USB3.0 ATX case
$180 - Corsair Special Edition White Graphite Series 600T ATX Case
$230 - Silverstone FT02S ATX Case
$230 - Silverstone FT02B ATX Case
$240 - Silverstone FT02S-W-USB3.0 ATX Case
$245 - Corsair Obsidian Series 800D CC800DW ATX Case
Hmm, thought they already upgraded the NZXT Phantom to have USB 3.0.
it would help me decide if i knew how easy it would be to watercool the sentey vs. antec because if it is similar i would rather just get the front panel usb 3 for the sentey
It appears the antec is actually better for water cooling by a bit but i could use some conformation
Haven't seen anyone use that Sentey case so can't vouch for its water cooling capability.
I noticed there are more tube holes(don't know what they are called lol) on the 1100 don't know if you have seen anyone use that for water-cooling. but at any rate ill probably just go with the Setney for looks and get one of those usb 3 front panel things and then post some information somewhere so others can make a more informed descision
More than likely you probably won't do water-cooling considering how expensive it can be. That money can often better be used towards faster parts.
alright thanks for the info i hope to at some point, when my 6870 stops being able to meet my needs, get a second one and crossfire them but i will need a better PSU to do that but again right now i am getting plenty of performance out of my 6870 right now can max almost any game and peg it at around 50 frames or more
Well I decided to go with the ASRock 990FX Extreme4 because it has usb3.0 front panel headers which the EXTREME3 did not have. Also it came with a 5.25 bay with 2 USB 3.0 adapter which is awesome because the board itself is more featured the the extreme 3. Yet one of those usb 3.0 front panel adapters costs about the price difference between the two. So it is the better choice to me but I could be totally wrong once again
Don't buy anything until those new AMD CPUs comes out.
