My order is in, what else do I need?
Nailz
So my order is on the way from NewEgg, see my sig for what I have coming.
Now I need to know what you recommend as far as software, drivers, etc. to assist me with OC'ing my video card or benchmarking, etc.
I was considering going with Vista as an OS, I have friends at Microsoft, but could also lean to XP if people think it may be safer at the moment.
Thanks as always for the help!
Personally, I'm not switching to Vista until Service Pack 1 comes out. But other people have had far better experience with Vista than I do.
Go to guru3d.com and check out all the tools for oc'ing/benchmarking your vidcard. I use RivaTuner and 3DMark.
Vista is crap for gaming and pretty much everything else. Windows XP is less resource intense allowing more of your resources to go towards the applications you want to run. Vista bogs down my friend's E6600 machine enough to put me off on their OS until I absolutely need it. No one needs that much overhead from the OS, but that's just my opinion.
I thought that that Nvidia card came with a tool for OCing?
I have to say vista has gotten a better. I've been keep up with it since RC1. Even when the retail version was released it was crap. My first install of retail was at least 3 months ago. I just installed it on Sunday again and lets just say I'm having a much better experience. Microsoft really hit the ball on target with "features". I'm one of those people willing to give up a little performance for a lot of eye candy. But by the end of this week, I should have a dual boot going :D
Thanks all, and an additional question for you..... What kind of settings should I be trying to go for to get some mild OC'ing for my CPU and RAM?
Any particular settings that will help me get a little more mileage out of what I am building out?
Thanks!
Check out the OC database to get an idea of what your chip is capable of. Its in the Intel CPU subforum.
I was thinking the same but did it anyway ebcause of Halo 2 , and I'm glad I did. Honestly, Vista works better than XP Pro for me.
I did use Vista for a while in a dual boot configuration. It wasn't one big item that made me stay on XP, it was the little things that made put me off about Vista. So XP works better for me but it's up to the OP to decide whether the pros outweigh the cons.
if you need to purchase an os, go with vista. drivers are getting better for it and its not as bad as some people make it out to be. plus you're going to have to make the jump sooner or later so you might as well save yourself some money and go with vista now.
