My new system is NOT POSTING!!
boy_wonder
Okay, here are the specs:
MSI K8N Neo4 Platinum SLI Mobo
AMD Athlon 64 3000+ Winchester Core
2x MSI NX6600GT PCI-E 128mb GPU's
2x512mb Corsair ValueSelect PC3200 RAM
Western Digital 120 GB 7200 RPM EIDE Hard Drive
Aopen 16x DVD R/RW Drive
Xclio 450 Watt Power Supply
Aspire X-Dreamer II Green Case
Thermaltake Venus 12 CPU HSF
Alright, I built and rebuilt this system 3 times from the ground up. After the first time, I had to RMA my mobo for a broken capacitor. After I got it back, I built it up two more times, but it still won't post. I just get a "Please Check Signal Cable" on my screen. I have tried virtually everything. I checked my SLI setup, I tried each card seperately, I have tried the RAM seperately and in different slots. So right now, I am out of ideas. I have two more things that I still have to test.
I wanted to know if I can use my old Radeon 9200 SE regular PCI GPU in this mobo to test and see if it's the video card's problem. Can I do this, or will this do damage to the system?
I also wanted to know if the speaker for this mobo (the one that makes the error beeps) is on the mobo already, or if you have to connect something. I figure someone will know since there is a long post dedicated to this one mobo on the top of this forum. That way, I can check if the CPU and mobo are working by removing the RAM, powering it on, and then seeing if beeps arise. So, do I have to connect something, or is it on there already?
If there is a faulty part, I would think it's the CPU because the mobo gets tested after it is RMA'd, and the video cards I got were both tested before I bought them. One was straight from MSI refurb, and one was from another seller that I know tests his stuff before he sells it. The memory is brand new from Corsair. Would I be correct in thinking that it is the CPU, because I can very easily exchange it for another brand new one.
And finally, does anyone have any more suggestions for me? Anything to do or check? Thank you for all your help in advance!
I would try the PCI card to see if you get video. It won't damage the computer. You need the DBracket2 accessory to test for errors, but MSI only includes it with some boards. I didn't get one either with my board :(. Supposedly, if you call MSI they will send you one for nothing. I can't confirm this though because I sent an e-mail and never heard back.
