I'm starting on a new build having endured the same PC for a good 4 years now which as you can imagine has become unusable when it comes to games. I'm upgrading from a P4 3.2 with an X800 pro so I'm sure I'll see a pretty good increase in speed! Although I built this old PC myself, it was simply made up of purchased components (stock coolers, case with low powered PSU and one fan) so this is my first build where I'll be doing a bit more customisation.
The main purpose of this PC is for gaming (mainly sports, FPS, RTS etc) but not exclusively, though considering the components below it should be fit for most other purposes anyway.
Another key thing is my old PC is unbelievably loud and hot so I want this one to be quiet and cool (on air).
I haven't listed any links to the components below, primarily because I live in the UK so the likes of Newegg, Buy and Tiger Direct etc. are not an option. However I can get the main components through my work for slightly cheaper than retail so have listed the prices.
I only need to buy the main components as I already have a keyboard, mouse, speakers and a 17" 1280x1024 monitor. I also have a DVD writer and Windows XP 32bit. I plan on keeping this PC for as long as possible (3 years?) whilst still being able to play the latest games at a reasonable quality.
My budget is around the £500 mark which at the current exchange rate is around $1000 US, however due to the UK being overpriced greatly, the components I've selected are probably comparable to that of a $750-800 build.
So here's the components I've picked out...
CPU - Q6600 (£120 / $240)
- I plan to overclock this to around the 3GHz mark
- Plenty of power for the future when quad core can be fully utilised
CPU Cooler - Arctic Cooling Freezer Pro 7 (£15 / $30)
- Read good things about this and the general consensus is that it is cheap, quiet and keeps the CPU nice and cool
Case / PSU - Antec Sonata Plus 550 (£85 / $170)
- Case same as Antec Solo so keeps the noise down and has reasonable airflow
- PSU is plenty powerful, modular, quiet and I've read good reviews about it
GPU - 8800GTS 512Mb (£130 / $260)
- Overly powerful for my monitor but I may upgrade it in the near future, and will be able to play the latest games for a while. Also quite quiet even with the stock fan
Motherboard - Gigabyte-GA-P35-DS3L (£50 / $100)
- Should allow my CPU to hit 3GHz right? Else I'd get the DS3R instead. I don't think I'll need more than 4 SATA ports as shouldn't ever have more than 2 hard drives and 2 optical drives - unless there's anything else the SATA could be useful for that I haven't thought of?
Memory - 4GB DDR II 800MHz from Corsair or Kingston (£45 / $90)
- This should be plenty fast enough for the Q6600 from what I read
Hard drive - WD 6400AAKS 640Gb, 16MB, 7200RPM - (£45 / $90)
- Quiet and spacious
Total = £490 / $980
So that's what I have so far - is there anything else I need or anything that should change? Perhaps I need an additional fan (or fans) although I've read the one which comes with the Sonata is quite good.
All comments and advice is welcome
Cheers
Dan
Total = £490 / $980
Cheers
Dan
